Thanks, Found it and it seems to be working now.
Mike
Mike
--- In vantage@yahoogroups.com, Karen Schoenung <kschoenung@...> wrote:
> I am sure you can find something on Epicor Website and it is in HELP too (for Vantage 8.03.409C).
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mike Numbers
> Sent: Tuesday, February 26, 2013 10:10 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Customization field not being populated
> How do you do that. I looked at the Customization Tools and I don’t see anything about foreign key. Is there an example documented someplace that I could see?
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mark Wagner
> Sent: Tuesday, February 26, 2013 9:37 AM
> Subject: Re: [Vantage] Customization field not being populated
> Have you tried bringing in the shiphed table as a foreign key view to see if that will work?
> From: Mike Numbers mnumbers@...<mailto:mnumbers%40cignys.com> >
> Sent: Tuesday, February 26, 2013 9:33 AM
> We have added to the ARForm (Invoice) the Tracking number and weight from Shiphead. This works. My problem is in trying to customize Invoice Tracker, the ShipHead data doesn’t appear to be populated even though the customization allows you to bind to ShipHead.
> Mike
> From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of Mark Wagner
> Sent: Thursday, February 21, 2013 1:50 PM
> To: mailto:vantage%40yahoogroups.com
> Well, never say never I guess. I went in one more time and tried it again. I am pulling invcdetail with shiphead using company and pack number as joins in crystal. After bringing in shiphead and using database expert to fix the joins it worked.
> Try it and see
> From: Mike Brown mailto:mbrown%40dsmfg.com >
> To: "mailto:vantage%40yahoogroups.com mailto:vantage%40yahoogroups.com >
> Sent: Thursday, February 21, 2013 12:58 PM
> Smells like a bug to me.
> Michael Brown
> Master Scheduler / Programmer
> D&S Manufacturing
> 715-284-5376 Ext. 344
> Sent: Thursday, February 21, 2013 10:29 AM
> Mike, we are having the same issue with adding tracking number to the AR Invoice. I have not reported this to Epicor support but several of us have looked at it and it looks like a bug to us
> From: mike.numbers mailto:mnumbers%40cignys.com>
> Sent: Wednesday, February 20, 2013 2:34 PM
> Subject: [Vantage] Customization field not being populated
> I am trying to customize Invoice Tracker by adding to the Summary page the Tracking number of the shipment. I have added an epiTextBox and then on EpiBinding selected ShipHead.TrackingNumber. When I bring up an invoice that has a tracking number, nothing appears in the box. I have even added an epiTextbox for the ShipHead.PackNum and it is blank. Am I forgeting to do something, or is there a reason the ShipHead record is not being populated on the Invoice tracker?
> 9.04.507A
> Mike
