Much ado about nothing. After engaging brain I found that the porView in
Inspection Processing dumps its data to the RcvDtl table. So, Number01 is
Number01 in RcvDtl. No need to invoke any of the fancy customizations listed
below.
-Karl
To: Vantage Group <vantage@yahoogroups.com>
Sent: Fri, April 29, 2011 1:27:09 PM
Subject: [Vantage] Customization for Sample Size
Â
In order to capture the sampling size of PO receipts in Inspection Processing,
I've attached a FKV (porView.POLinePartNum) to porView with a Like Column of
Part.PartNum. I then added AD.Receipt along with bo and IF.IReceipt to the
Custom Assemblies and finally linked Number01 to the datasource of PORecpt.
The problem is that the field is grayed out and in looking at the properties of
the Data element, DataReadOnly is True.
Do I need to put in a script customization to turn the extended property to
false? Any other obvious reasons this field would not be available for input?
below.
-Karl
Â
