Customization for Transit Days
Hi,
For now, our biggest concern is to include weekends for transit days calcs...Below I have included the "meat" of the formulas I used for my calculations and verified manually and in Excel. If anyone wants to test themselves, just let me know if you find anything incorrect.
Karen
'//Check Need By Date lands on Sunday or Saturday
IF WEEKDAY(edv.dataView(edv.Row)("NeedByDate")) = 1 THEN
wknd = wknd + 1
Else IF WEEKDAY(edv.dataView(edv.Row)("NeedByDate")) = 7 THEN
wknd = wknd + 1
Else
wknd = wknd + 0
END If
myNumber = myNumber + wknd
edv.dataView(edv.Row)("ReqDate") = edv.dataView(edv.Row)("NeedByDate").AddDays(myNumber * -1)
'//Check Days Between lands on Sunday or Saturday
For X = 1 to myNumber
IF WEEKDAY(edv.dataView(edv.Row)("NeedByDate").AddDays(X * -1)) = 1 THEN
calcwknd = calcwknd + 1
Else IF WEEKDAY(edv.dataView(edv.Row)("NeedByDate").AddDays(X * -1)) = 7 THEN
Else
calcwknd = calcwknd + 0
End If
Next X
myNumber = myNumber + calcwknd
'//Check Calculated Ship By Date lands on Sunday or Saturday
IF WEEKDAY(edv.dataView(edv.Row)("ReqDate")) = 1 THEN
endwknd = endwknd + 2
Else IF WEEKDAY(edv.dataView(edv.Row)("ReqDate")) = 7 THEN
endwknd = endwknd + 1
Else
endwknd = endwknd + 0
End If
myNumber = myNumber + endwknd
--- In vantage@yahoogroups.com, "karen_schoenung" <kschoenung@...> wrote:
> Hi,
> I used this as a sample and did create the foreign key, sub key and code to update the ship by date after updating need by date...But, now I would like to incorporate the Production? calendar in Vantage. Any ideas where to start?
> Thanks,
> Karen
> --- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@> wrote:
> > That sounds like good advice. I'm probably going to take that advice.
> > I think that I will launch the Transit Days field into the live
> > database now. Then at some later date, I can work on the
> > calendar/date math when I am no longer under pressure to get the
> > customization quickly deployed to the users.
> > That way, I can take my time and consider those weekends & holidays
> > issues brought up by Charlie which I had not thought about before.
> > Lynn
> > --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@>
> > wrote:
> > > My pleasure Lynn. Some great experienced power users out there
> > helped me (and still do) when we 1st started on Vantage and I like
> > returning the favor.
> > > Advice? - Don't get into the date math yet. (As you suggested) -
> > See if just displaying the info (and letting people do the simple
> > mental math) gives you the desired productivity boost.
> > > It is all too easy to incrementally overcustomize and wake up one
> > day to discover you have seriously impact application performance.
> > > If you reach a point where you think it really would help to do the
> > calc for the users, re-post and there is probably some code that
> > could be shared to save you time.
> > > Rob
> > > --- On Wed, 10/15/08, Lynn <lynn.khalife@> wrote:
> > > From: Lynn <lynn.khalife@>
> > > Subject: [Vantage] Re: Customization for Transit Days
> > > To: vantage@yahoogroups.com
> > > Date: Wednesday, October 15, 2008, 2:33 PM
> > > It works!
> > > Thank you, thank you, thank you Rob.
> > > I had never before heard of a SubTable View.
> > > Following the instructions in your email, I created the SubTable
> > > View, then I re-added a control box back onto the Order Entry
> > screen
> > > and connected it to my newly added (SubTable View) Datasource,
> > > ShipToInfo.Number01 . Then I exited Customization and went into
> > Order
> > > Entry. As soon as I opened an existing order, the value for Transit
> > > Days immediately appeared!
> > > Now I can move on to the issue to working with calandar and date
> > > math. However, even if I cannot get the date math to work
> > perfectly,
> > > the Order Entry users will be very happy that they can see the
> > > Transit Days value on the Order Entry Header screen; then at least
> > > they have a number to do their own calendar calculation to
> > determine
> > > a ShipBy date.
> > > I have been trying to get this Transit Days field to work for a
> > very,
> > > very long time. Now that I know about a SubTable View in Vantage,
> > > I'm sure that I will be using this knowledge in future
> > customizations.
> > > Thank you again.
> > > Lynn
> > > --- In vantage@yahoogroups .com, Robert Brown <robertb_versa@ ...>
> > > wrote:
> > > > Lynn,
> > > > Â
> > > > Don't quit on it yet. You're on the right track.
> > > > It is (seems more often than not unfortunately) not always
> > possible
> > > to create a DIRECT FKV from a seemingly appropriate native table to
> > > the foreign table you want to join & bind to the app.
> > > > You have to get creative and relying on some trial and error luck
> > > as a result of the lack of documentation (and the poor environment
> > > provided that offers little error resolution guidance).
> > > > Try creating a simple FKV from the native OrderRel table to table
> > > Customer.
> > > > Then (from your FKV Customer) try creating a SubTable View to
> > table
> > > ShipTo.
> > > > SubTable Views allow YOU to decide what fields to create the join
> > > through.
> > > > Typically, you are always going to have Company as the 1st joined
> > > field but, depending upon what version you are on (and what bugs it
> > > has), it is possible company data isn't populated in the tables you
> > > are trying to connect the dots through. (Look at the tables raw via
> > a
> > > simple BAQ dump or via odbc SQL if you encounter problems.)
> > > > I'd guess your joins would be through Company, CustID & ShipToID.
> > > > It can be a very frustrating trial and error process. I've had to
> > > go as deep as 3 FKVs until I finally can get a SubTable to bring in
> > > the data I'm after.
> > > > If all else fails (and it might), open the Custom Object Explorer
> > > (Adapter tab) and look at the methods and properties (as well as
> > > sample code for each) for the ShipToAdapter. Make note of the
> > > assemblies required for the adapter as you will likely have to add
> > > them to the app as Custom Assemblies (to support the adapter).
> > > > You should find a suitable search ("Get...") method that you can
> > > build a subroutine around that will allow you to retrieve your
> > > ShipTo.Number01 value associated with each order/line/release' s
> > > Customer & ShipTo ID.
> > > > Store it in a defined temp variable or an array (or permanently
> > > save it to an OrderRel.Number# # field).
> > > > Then you are ready to start doing some date math.
> > > > ...I know... (yuck!) It can be done though... It takes some
> > > persistence and in the end, you'll learn a lot more about how
> > Vantage
> > > works than you might have if it was as easy as falsely advertised.
> > > > Rob
> > > > --- On Wed, 10/15/08, Lynn <lynn.khalife@ ...> wrote:
> > > > From: Lynn <lynn.khalife@ ...>
> > > > To: vantage@yahoogroups .com
> > > > Date: Wednesday, October 15, 2008, 11:45 AM
> > > > Yes, that sums it up exactly.
> > > > I finished the Customer Maintenance customization. And I have
> > > > already entered TransitDays data for several Ship-To locations.
> > > > Then, I downloaded information on FKV's from the Epicor website
> > and
> > > > tried to create a FKV to the ShipTo table from the OrderHed. This
> > > is
> > > > where I am completely unsuccessful.
> > > > Following the instructions in Answerbook # 6415MPS, I create a
> > new
> > > > custom view named "CustShipToInfo" . I select OrderHed as my
> > Parent
> > > > View Name. Then I move to Column Name. I think this is where I
> > run
> > > > into a problem. CustNum is available as a Column Name. But there
> > > > are 2 issues I that I don't know how to overcome. First,
> > ShipToNum
> > > > is not one of the available Column Names for the Parent View
> > > > OrderHed. Second, when I choose CustNum, I still need to tell the
> > > > database which ShipToNum I want and there is not a place to add a
> > > > second Column Name for the same FKV.
> > > > The situation is the same if I select OrderDtl as the Parent View
> > > > Name.
> > > > The situation is different when I select OrderRel as the
> > ParentView
> > > > Name. When OrderRel is the Parent, I am allowed to choose
> > ShipToNum
> > > > as my column name; however, the LikeColumnValue populates
> > > > as "ShipHead.ShipToNum ". There are 2 issues here. First, the
> > > > ShipHead table does not contain my data. My data is in the ShipTo
> > > > table. Second, I still need to tell the database which CustNum to
> > > > use with the ShipToNum.
> > > > I don't know what to do.
> > > > Thanks.
> > > > Lynn
> > > > wrote:
> > > > > Lynn,
> > > > > OK. Let me see if I get your planned intent by repeating - then
> > I
> > > > can recommend:
> > > > > You either already have (or plan to) store an integer "Transit
> > > > Days" value in the ShipTo table (presumably in a ud field like
> > > > ShipTo.Number01) .
> > > > > That means Customer Maintenance will require a customization to
> > > > expose ShipTo.Number01 and display it as read-only false so your
> > > > people can edit it and add the info as new addresses are added
> > over
> > > > time.
> > > > > Once that data is available, in Order Entry you'll want to add
> > > the
> > > > custom assemblies needed to support the adapter & BO methods
> > > > associated with the Ship To table. Then you can create a Foreign
> > > Key
> > > > View to the ShipTo table from the native OrderRel view.
> > > > > That then makes ShipTo.Number01 available to the Order Entry
> > app
> > > to
> > > > display or use in VB subroutines and/or functions to do the
> > offset
> > > > days calculation.
> > > > > In order to do that offset days calculation, you need a
> > calendar
> > > > that defines your normal business/shipping days. You can either
> > > > create one specifically for shipping or use your default company
> > > > calendar stored in the ProdCal table (with exceptions - holidays -
> > > > stored in ProdCalDay).
> > > > > (We found these calendars ridiculously conceived so, while we
> > > must
> > > > use & maintain them for resource capacity, etc., we actually
> > > maintain
> > > > a very simple holiday calender schema in a SQL server db. At some
> > > > point we may move that to a UD table.)
> > > > > Once you've settled upon the source of your calendar, you'll
> > need
> > > > to write some functions to use the calendar data and your
> > > > ShipTo.Number01 offset field to backwards calculate you Ship Date
> > > > from the customer Need By date (or vice-versa if that is your
> > > > process).
> > > > > Am I understanding your need now?
> > > > > If so, does what I describe (as a possible way to obtain it)
> > make
> > > > sense to you?
> > > > > Rob
> > > > > Date: Wednesday, October 15, 2008, 8:47 AM
> > > > > Hi Rob:
> > > > > For some customers, we use our own trucks. For others, the
> > > customer
> > > > > has determined the carrier and we have been using the same
> > > carrier
> > > > > for the same shipto location for years.
> > > > > In nearly every case for every customer, we use the same
> > Carrier
> > > > for
> > > > > all product that goes to a specific location. Therefore, in our
> > > > > case, the Transit Days will rarely, if ever, change for a
> > > specific
> > > > > Shipto location.
> > > > > Hence, it makes sense for us to use a single Transit Days field
> > > in
> > > > > the ShipTo table. If we were constantly using different
> > carriers,
> > > > it
> > > > > would be much more complicated. This is probably why Epicor
> > > didn't
> > > > > build this feature into the Order Entry design. If we used many
> > > > > carriers for a single shipto address, I would probably have to
> > > add
> > > > a
> > > > > separate userdefined table to store this information.
> > > > > And even though the Transit Days will always be estimates, it
> > is
> > > > more
> > > > > efficient and effective if the Order Entry clerks could see the
> > > > > Transit Days on the same screen during Order Entry.
> > > > > As it is now, they have to leave that screen and go back to the
> > > > main
> > > > > menu and open the Customer file, search for the Customer, then
> > do
> > > a
> > > > > second Search for the correct Customer ShipTo code in order to
> > > get
> > > > > the Transit Days to calculate a reliable "Ship By" date based
> > > upon
> > > > > the Customer's "Need By" date.
> > > > > Prior to this, our Transit days are in our old database
> > software
> > > > > which matches a Carrier Name with the customer ShipTo address.
> > We
> > > > > are implementing Vantage and want to have the same feature in
> > > > Vantage
> > > > > that we do with our old software.
> > > > > But nothing will work until I can figure out how to pass the
> > > field
> > > > > from ShipTo to OrderHed.
> > > > > I appreciate your input and hints very much.
> > > > > Lynn
> > > > > wrote:
> > > > > > Lynn
> > > > > > How do you know the working day offset to apply between the
> > > > > customer Need By date and your Ship Date for individual order
> > > line
> > > > > releases? What is your data source for this info?
> > > > > > Some simple 'rule of thumb' based on ship to address and/or
> > > ship
> > > > > via method or do you have the info in some data format from
> > your
> > > > > commonly used carriers? (Example: NextDay Air is 1 business day
> > > no
> > > > > matter what destination it is. UPS provides ground service
> > > transist
> > > > > times based upon your ship from zip and the ship to zip zones.
> > > Big
> > > > > LTL carriers can provide general guesstimate transist times
> > with
> > > > > about the same reliability of UPS. Small LTL's are often a
> > sheer
> > > > > guess, etc.,.)
> > > > > > The date math itself is pretty straight forward (at least
> > using
> > > > VB)
> > > > > once you have an accessible source for the offset data. We've
> > got
> > > a
> > > > > number of customizations that do business day offset math.
> > > > > > (No sense in doing the math unless you have a source of data
> > > for
> > > > > the math to be done with.)
> > > > > > Rob
> > > > > > Date: Tuesday, October 14, 2008, 9:15 PM
> > > > > > I didn't think it would be possible to put a
> > > > > calculation on an Epicor
> > > > > > field. No, there isn't any reason that I need to add my own
> > > > custom
> > > > > > Ship By date. You are correct, I would much prefer to update
> > > the
> > > > > > Epicor-provided Ship-by date field.
> > > > > > But, my biggest hurdle right now is that I don't know how to
> > > pass
> > > > > the
> > > > > > TransitDays from the ShipTo table to the OrderHed table.
> > > > > > Lynn
> > > > > > --- In vantage@yahoogroups .com, "CharlieSmith" <CSmith@>
> > wrote:
> > > > > > > Why not just update the ship by date with the transit days
> > > > > through
> > > > > > your
> > > > > > > customization. This will be much more advantageous because
> > > many
> > > > > of
> > > > > > the
> > > > > > > reports, defaults and analysis is based on the ship-by date.
> > > > > > > Is there a business reason why you would need a custom ship
> > > by
> > > > > date?
> > > > > > > Charlie Smith
> > > > > > > 2W Technologies LLC
> > > > > > > From: vantage@yahoogroups .com [mailto:vantage@
> > > > yahoogroups .com]
> > > > > On
> > > > > > Behalf
> > > > > > > Of Lynn
> > > > > > > Sent: Tuesday, October 14, 2008 4:20 PM
> > > > > > > Subject: [Vantage] Customization for Transit Days
> > > > > > > On the Order Entry screens, the "Ship By" date defaults to
> > > the
> > > > > same
> > > > > > > date as the "Need By" date.
> > > > > > > I have added a field (ShipTo.Number01) to Customer Ship To
> > > > entry
> > > > > > and
> > > > > > > labeled it "Transit Days".
> > > > > > > On the Order Entry screens, I would like to hide the Epicor-
> > > > > > > supplied "Ship By" date field (OrderHed.RequestDa te) and
> > add
> > > > my
> > > > > own
> > > > > > > Ship By date field (OrderHed.Date01) .
> > > > > > > During Order Entry, upon selecting a Customer ShipTo code,
> > I
> > > > want
> > > > > > to
> > > > > > > automatically pull the Transit Days number
> > (ShipTo.Number01)
> > > > from
> > > > > > the
> > > > > > > Customer ShipTo table and bring that value into a field
> > named
> > > > > > > OrderHed.Number01. Then I would like to subtract that value
> > > > from
> > > > > > the
> > > > > > > Need By date to automatically populate the correct Ship By
> > > date
> > > > > in
> > > > > > my
> > > > > > > new OrderHed.Date01 field.
> > > > > > > I cannot figure out how to get the Transit Days data from
> > > > > > > ShipTo.Number01 to OrderHed.Number01.
> > > > > > > Can someone shed some light on what I am missing with this
> > > > > > > Customization?
> > > > > > > I have pulled information on FKV's from the Epicor website
> > > I
> > > > am
> > > > > > > still in the dark about how to transfer this data from one
> > > > table
> > > > > to
> > > > > > > the next.
> > > > > > > And how do other people working in Order Entry determine
> > what
> > > > to
> > > > > > > enter for a "Ship By" date in order to ship the product
> > early
> > > > > > enough
> > > > > > > to meet the Customer's Need By Date?
> > > > > > > I'm in Vantage 8.03.404
> > > > > > > Lynn
> > > > > > > [Non-text portions of this message have been removed]
On the Order Entry screens, the "Ship By" date defaults to the same
I have added a field (ShipTo.Number01) to Customer Ship To entry and
supplied "Ship By" date field (OrderHed.RequestDate) and add my own
Ship By date field (OrderHed.Date01).
During Order Entry, upon selecting a Customer ShipTo code, I want to
automatically pull the Transit Days number (ShipTo.Number01) from the
Customer ShipTo table and bring that value into a field named
OrderHed.Number01. Then I would like to subtract that value from the
Need By date to automatically populate the correct Ship By date in my
Customization?
I have pulled information on FKV's from the Epicor website & I am
still in the dark about how to transfer this data from one table to
the next.
And how do other people working in Order Entry determine what to
enter for a "Ship By" date in order to ship the product early enough
Lynn
You would also need to skip weekend and holidays when subtracting
transit days for this type of calculation to work.
Patrick Winter
Of Lynn
Sent: Tuesday, October 14, 2008 3:20 PM
Customization?
the next.
Lynn
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
Why not just update the ship by date with the transit days through your
customization. This will be much more advantageous because many of the
Is there a business reason why you would need a custom ship by date?
Charlie Smith
2W Technologies LLC
Of Lynn
Customization?
the next.
Lynn
I didn't think it would be possible to put a calculation on an Epicor
field. No, there isn't any reason that I need to add my own custom
Ship By date. You are correct, I would much prefer to update the
But, my biggest hurdle right now is that I don't know how to pass the
Lynn
your
the
> Charlie Smith
> 2W Technologies LLC
Behalf
> Of Lynn
and
to
the
the
my
> Customization?
> the next.
enough
> Lynn
Thanks. I had forgotten about that.
Lynn
> Patrick Winter
Behalf
> Of Lynn
and
to
the
the
my
> Customization?
> the next.
enough
> Lynn
Lynn
How do you know the working day offset to apply between the customer Need By date and your Ship Date for individual order line releases? What is your data source for this info?
Some simple 'rule of thumb' based on ship to address and/or ship via method or do you have the info in some data format from your commonly used carriers? (Example: NextDay Air is 1 business day no matter what destination it is. UPS provides ground service transist times based upon your ship from zip and the ship to zip zones. Big LTL carriers can provide general guesstimate transist times with about the same reliability of UPS. Small LTL's are often a sheer guess, etc.,.)
The date math itself is pretty straight forward (at least using VB) once you have an accessible source for the offset data. We've got a number of customizations that do business day offset math.
(No sense in doing the math unless you have a source of data for the math to be done with.)
Rob
Lynn
your
the
> Charlie Smith
> 2W Technologies LLC
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
> Of Lynn
and
> supplied "Ship By" date field (OrderHed.RequestDa te) and add my own
to
the
the
my
> Customization?
> the next.
enough
> Lynn
Hi Rob:
For some customers, we use our own trucks. For others, the customer
has determined the carrier and we have been using the same carrier
In nearly every case for every customer, we use the same Carrier for
case, the Transit Days will rarely, if ever, change for a specific
Shipto location.
Hence, it makes sense for us to use a single Transit Days field in
the ShipTo table. If we were constantly using different carriers, it
would be much more complicated. This is probably why Epicor didn't
carriers for a single shipto address, I would probably have to add a
And even though the Transit Days will always be estimates, it is more
As it is now, they have to leave that screen and go back to the main
menu and open the Customer file, search for the Customer, then do a
second Search for the correct Customer ShipTo code in order to get
the Transit Days to calculate a reliable "Ship By" date based upon
Prior to this, our Transit days are in our old database software
which matches a Carrier Name with the customer ShipTo address. We
are implementing Vantage and want to have the same feature in Vantage
But nothing will work until I can figure out how to pass the field
Lynn
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
wrote:
> Lynn
guess, etc.,.)
> Rob
> From: Lynn <lynn.khalife@...>
the
> Lynn
through
> your
of
> the
date?
> > Charlie Smith
> > 2W Technologies LLC
On
> Behalf
> > Of Lynn
same
> and
own
> to
> the
> the
in
> my
> > Customization?
to
> > the next.
> enough
> > Lynn
Lynn,
OK. Let me see if I get your planned intent by repeating - then I can recommend:
You either already have (or plan to) store an integer "Transit Days" value in the ShipTo table (presumably in a ud field like ShipTo.Number01).
That means Customer Maintenance will require a customization to expose ShipTo.Number01 and display it as read-only false so your people can edit it and add the info as new addresses are added over time.
Once that data is available, in Order Entry you'll want to add the custom assemblies needed to support the adapter & BO methods associated with the Ship To table. Then you can create a Foreign Key View to the ShipTo table from the native OrderRel view.
That then makes ShipTo.Number01 available to the Order Entry app to display or use in VB subroutines and/or functions to do the offset days calculation.
In order to do that offset days calculation, you need a calendar that defines your normal business/shipping days. You can either create one specifically for shipping or use your default company calendar stored in the ProdCal table (with exceptions - holidays - stored in ProdCalDay).
(We found these calendars ridiculously conceived so, while we must use & maintain them for resource capacity, etc., we actually maintain a very simple holiday calender schema in a SQL server db. At some point we may move that to a UD table.)
Once you've settled upon the source of your calendar, you'll need to write some functions to use the calendar data and your ShipTo.Number01 offset field to backwards calculate you Ship Date from the customer Need By date (or vice-versa if that is your process).
If so, does what I describe (as a possible way to obtain it) make sense to you?
Rob
Hi Rob:
Shipto location.
Lynn
wrote:
> Lynn
guess, etc.,.)
> Rob
the
> Lynn
through
> your
of
> the
date?
> > Charlie Smith
> > 2W Technologies LLC
> > From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com]
On
> Behalf
> > Of Lynn
same
> and
own
> to
> the
> the
in
> my
> > Customization?
to
> > the next.
> enough
> > Lynn
Then, I downloaded information on FKV's from the Epicor website and
tried to create a FKV to the ShipTo table from the OrderHed. This is
Following the instructions in Answerbook # 6415MPS, I create a new
custom view named "CustShipToInfo". I select OrderHed as my Parent
View Name. Then I move to Column Name. I think this is where I run
are 2 issues I that I don't know how to overcome. First, ShipToNum
Name.
The situation is different when I select OrderRel as the ParentView
Name. When OrderRel is the Parent, I am allowed to choose ShipToNum
as "ShipHead.ShipToNum". There are 2 issues here. First, the
Thanks.
Lynn
wrote:
> Lynn,
can recommend:
ShipTo.Number01).
time.
days calculation.
process).
sense to you?
> Rob
> Hi Rob:
for
> Shipto location.
it
a
more
main
Vantage
> Lynn
> wrote:
> > Lynn
> guess, etc.,.)
VB)
> > Rob
custom
> the
> > Lynn
> through
> > your
> of
> > the
> date?
> > > Charlie Smith
> > > 2W Technologies LLC
yahoogroups .com]
> On
> > Behalf
> > > Of Lynn
> same
entry
> > and
my
> own
want
> > to
from
> > the
from
> > the
> in
> > my
> > > Customization?
am
table
> to
> > > the next.
to
> > enough
> > > Lynn
Lynn,
Â
It is (seems more often than not unfortunately) not always possible to create a DIRECT FKV from a seemingly appropriate native table to the foreign table you want to join & bind to the app.
You have to get creative and relying on some trial and error luck as a result of the lack of documentation (and the poor environment provided that offers little error resolution guidance).
Try creating a simple FKV from the native OrderRel table to table Customer.
Then (from your FKV Customer) try creating a SubTable View to table ShipTo.
SubTable Views allow YOU to decide what fields to create the join through.
Typically, you are always going to have Company as the 1st joined field but, depending upon what version you are on (and what bugs it has), it is possible company data isn't populated in the tables you are trying to connect the dots through. (Look at the tables raw via a simple BAQ dump or via odbc SQL if you encounter problems.)
It can be a very frustrating trial and error process. I've had to go as deep as 3 FKVs until I finally can get a SubTable to bring in the data I'm after.
If all else fails (and it might), open the Custom Object Explorer (Adapter tab) and look at the methods and properties (as well as sample code for each) for the ShipToAdapter. Make note of the assemblies required for the adapter as you will likely have to add them to the app as Custom Assemblies (to support the adapter).
You should find a suitable search ("Get...") method that you can build a subroutine around that will allow you to retrieve your ShipTo.Number01 value associated with each order/line/release's Customer & ShipTo ID.
Store it in a defined temp variable or an array (or permanently save it to an OrderRel.Number## field).
...I know... (yuck!) It can be done though... It takes some persistence and in the end, you'll learn a lot more about how Vantage works than you might have if it was as easy as falsely advertised.
Rob
custom view named "CustShipToInfo" . I select OrderHed as my Parent
Name.
Thanks.
Lynn
wrote:
> Lynn,
can recommend:
ShipTo.Number01) .
time.
days calculation.
process).
sense to you?
> Rob
> Hi Rob:
for
> Shipto location.
it
a
more
main
Vantage
> Lynn
> wrote:
> > Lynn
> guess, etc.,.)
VB)
> > Rob
custom
> the
> > Lynn
> through
> > your
> of
> > the
> date?
> > > Charlie Smith
> > > 2W Technologies LLC
yahoogroups .com]
> On
> > Behalf
> > > Of Lynn
> same
entry
> > and
my
> own
want
> > to
from
> > the
from
> > the
> in
> > my
> > > Customization?
am
table
> to
> > > the next.
to
> > enough
> > > Lynn
It works!
View, then I re-added a control box back onto the Order Entry screen
ShipToInfo.Number01. Then I exited Customization and went into Order
math. However, even if I cannot get the date math to work perfectly,
they have a number to do their own calendar calculation to determine
a ShipBy date.
I have been trying to get this Transit Days field to work for a very,
I'm sure that I will be using this knowledge in future customizations.
Thank you again.
Lynn
wrote:
> Lynn,
> Â
Customer.
ShipTo.
through.
the data I'm after.
> Rob
is
> Name.
> Thanks.
> Lynn
> wrote:
> > Lynn,
> can recommend:
> ShipTo.Number01) .
> time.
the
Key
to
> days calculation.
must
maintain
> process).
> sense to you?
> > Rob
> > Hi Rob:
customer
carrier
> for
specific
> > Shipto location.
in
> it
didn't
add
> a
> more
> main
a
get
upon
> Vantage
field
> > Lynn
> > wrote:
> > > Lynn
line
ship
no
transist
Big
> > guess, etc.,.)
> VB)
a
for
> > > Rob
> custom
the
pass
> > the
> > > Lynn
> > through
> > > your
many
> > of
> > > the
by
> > date?
> > > > Charlie Smith
> > > > 2W Technologies LLC
> yahoogroups .com]
> > On
> > > Behalf
> > > > Of Lynn
the
> > same
> entry
> > > and
> my
> > own
> want
> > > to
> from
> > > the
> from
> > > the
date
> > in
> > > my
> > > > Customization?
I
> am
> table
> > to
> > > > the next.
> to
> > > enough
> > > > Lynn
My pleasure Lynn. Some great experienced power users out there helped me (and still do) when we 1st started on Vantage and I like returning the favor.
Advice? - Don't get into the date math yet. (As you suggested) - See if just displaying the info (and letting people do the simple mental math) gives you the desired productivity boost.
It is all too easy to incrementally overcustomize and wake up one day to discover you have seriously impact application performance.
If you reach a point where you think it really would help to do the calc for the users, re-post and there is probably some code that could be shared to save you time.
Rob
It works!
ShipToInfo.Number01 . Then I exited Customization and went into Order
a ShipBy date.
Thank you again.
Lynn
wrote:
> Lynn,
> Â
Customer.
ShipTo.
through.
the data I'm after.
> Rob
is
> Name.
> Thanks.
> Lynn
> wrote:
> > Lynn,
> can recommend:
> ShipTo.Number01) .
> time.
the
Key
to
> days calculation.
must
maintain
> process).
> sense to you?
> > Rob
> > Hi Rob:
customer
carrier
> for
specific
> > Shipto location.
in
> it
didn't
add
> a
> more
> main
a
get
upon
> Vantage
field
> > Lynn
> > wrote:
> > > Lynn
line
ship
no
transist
Big
> > guess, etc.,.)
> VB)
a
for
> > > Rob
> custom
the
pass
> > the
> > > Lynn
> > through
> > > your
many
> > of
> > > the
by
> > date?
> > > > Charlie Smith
> > > > 2W Technologies LLC
> yahoogroups .com]
> > On
> > > Behalf
> > > > Of Lynn
the
> > same
> entry
> > > and
> my
> > own
> want
> > > to
> from
> > > the
> from
> > > the
date
> > in
> > > my
> > > > Customization?
I
> am
> table
> > to
> > > > the next.
> to
> > > enough
> > > > Lynn
Lynn
> Rob
> It works!
screen
Order
perfectly,
determine
> a ShipBy date.
very,
customizations.
> Thank you again.
> Lynn
> wrote:
> > Lynn,
> > Â
possible
> Customer.
table
> ShipTo.
> through.
a
> the data I'm after.
Vantage
> > Rob
and
> is
new
Parent
run
ShipToNum
> > Name.
ParentView
ShipToNum
> > Thanks.
> > Lynn
> > wrote:
> > > Lynn,
I
> > can recommend:
> > ShipTo.Number01) .
over
> > time.
> the
> Key
app
> to
offset
> > days calculation.
calendar
> must
> maintain
need
> > process).
make
> > sense to you?
> > > Rob
> > > Hi Rob:
> customer
> carrier
Carrier
> > for
> specific
> > > Shipto location.
> in
carriers,
> > it
> didn't
> add
> > a
is
> > more
> > main
do
> a
> get
> upon
software
We
> > Vantage
> field
> > > Lynn
> > > wrote:
> > > > Lynn
> line
> ship
your
> no
> transist
> Big
with
sheer
> > > guess, etc.,.)
using
> > VB)
got
> a
> for
> > > > Rob
> > custom
> the
> pass
> > > the
> > > > Lynn
> > > through
> > > > your
> many
> > > of
> > > > the
> by
> > > date?
> > > > > Charlie Smith
> > > > > 2W Technologies LLC
> > yahoogroups .com]
> > > On
> > > > Behalf
> > > > > Of Lynn
> the
> > > same
> > entry
> > > > and
add
> > my
> > > own
I
> > want
> > > > to
(ShipTo.Number01)
> > from
> > > > the
named
> > from
> > > > the
> date
> > > in
> > > > my
> > > > > Customization?
> I
> > am
> > table
> > > to
> > > > > the next.
what
> > to
early
> > > > enough
> > > > > Lynn
Hi,
Karen
> Lynn
> > Rob
> > It works!
> screen
> Order
> perfectly,
> determine
> > a ShipBy date.
> very,
> customizations.
> > Thank you again.
> > Lynn
> > wrote:
> > > Lynn,
> > > Â
> possible
> > Customer.
> table
> > ShipTo.
> > through.
> a
> > the data I'm after.
> Vantage
> > > Rob
> and
> > is
> new
> Parent
> run
> ShipToNum
> > > Name.
> ParentView
> ShipToNum
> > > Thanks.
> > > Lynn
> > > wrote:
> > > > Lynn,
> I
> > > can recommend:
> > > ShipTo.Number01) .
> over
> > > time.
> > the
> > Key
> app
> > to
> offset
> > > days calculation.
> calendar
> > must
> > maintain
> need
> > > process).
> make
> > > sense to you?
> > > > Rob
> > > > Hi Rob:
> > customer
> > carrier
> Carrier
> > > for
> > specific
> > > > Shipto location.
> > in
> carriers,
> > > it
> > didn't
> > add
> > > a
> is
> > > more
> > > main
> do
> > a
> > get
> > upon
> software
> We
> > > Vantage
> > field
> > > > Lynn
> > > > wrote:
> > > > > Lynn
> > line
> > ship
> your
> > no
> > transist
> > Big
> with
> sheer
> > > > guess, etc.,.)
> using
> > > VB)
> got
> > a
> > for
> > > > > Rob
> > > custom
> > the
> > pass
> > > > the
> > > > > Lynn
> > > > through
> > > > > your
> > many
> > > > of
> > > > > the
> > by
> > > > date?
> > > > > > Charlie Smith
> > > > > > 2W Technologies LLC
> > > yahoogroups .com]
> > > > On
> > > > > Behalf
> > > > > > Of Lynn
> > the
> > > > same
> > > entry
> > > > > and
> add
> > > my
> > > > own
> I
> > > want
> > > > > to
> (ShipTo.Number01)
> > > from
> > > > > the
> named
> > > from
> > > > > the
> > date
> > > > in
> > > > > my
> > > > > > Customization?
> > I
> > > am
> > > table
> > > > to
> > > > > > the next.
> what
> > > to
> early
> > > > > enough
> > > > > > Lynn
