not when clicking to it, when clicking an object on it.
I changed the parent guid of the groupbox and moved it to the main sheet and it works. My test that was working on the main I moved to the new sheet and now it does not work.
I put two checkboxes on the new sheet, one bound to sugpodtl.checkbox01 and the other unbound. I can click the unbound, but as soon as focus is on the bound control it is locked.
it does not lock if there are no controls there.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Wednesday, November 28, 2012 4:08 PM
To: Vantage
Subject: Re: [Vantage] Customization New Sheet
That's strange,
So you are just adding a brand new sheet and then when you click over to it it locks up? Does it lock up if there are no controls on there?
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
Greg
To: Vantage
That's strange,
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Nov 28, 2012 at 4:03 PM, Greg Payne <gpayne@...>wrote:
> I have a sheet with 5 checkboxes and 4 txt fields on PO suggestion.
> When I click the sheet to change data the program locks.
> I have removed the sheet and added again, but still the same. I set
> the extended properties enabled to true and readonly to false.
> if I put the same field on the main page, it works.
> What needs to be set to enable editing?
> Thanks for your help.
> Greg Payne
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including
> attachments, is privileged and confidential. It is intended only for
> the exclusive use of the addressee. If the reader of this message is
> not the intended recipient, or the employee or agent responsible for
> delivering it to the intended recipient, you are hereby notified that
> any dissemination, distribution or copying of this communication is
> strictly prohibited. If you have received this communication in error,
> please notify us at 727-578-6280 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in
> the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
> Export of this material is restricted by the Arms Export Control Act
> (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons
> without prior approval form the U.S. Department of State."
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
