Customization on RMA Dispostions called from Inspection Processi
When I put the Calling App value in the Called From field, it began working.
You, sir, are a steely-eyed missile man!
Have a great weekend,
Ernie
--- In vantage@yahoogroups.com, "Elizabeth" <gracefulthreads@...> wrote:
> So far not working.
> When I launch the button in Developer mode, I get the following popup:
> Process Key: Epicor.Mfg.UI.RMADispEntry
> Calling App: Epicor.Mfg.UI.InspectionProcessingEntry
> MenuID:
> In Process Calling Maintenance, the three fields are:
> Called Process Reference
> Called From
> MenuID
> In the MenuID field, I've put the reference to a menu item that has the customization attached (in this case, OMGO3016). I've left the Called From field blank. In the Called Process Reference I've tried:
> Epicor.MFG.UI.RMADispEntry
> App.RMADispEntry.RMADispForm
> but neither seems to work properly. After entering one of these, do I need to use one of the items off the Actions menu to initialize it?
> Thanks,
> Ernie
> --- In vantage@yahoogroups.com, Jose Gomez <jose@> wrote:
> > Go to Process calling maintenance and leave the Called From Blank then set
> > the rest to the customized menu
> > *Jose C Gomez*
> > *Software Engineer*
> > *T: 904.469.1524 mobile
> > E: jose@
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > <http://www.usdoingstuff.com>
> > *Quis custodiet ipsos custodes?*
> > On Fri, Dec 7, 2012 at 1:17 PM, Elizabeth <gracefulthreads@> wrote:
> > > 9.04.507A SQL.
> > > I've just put a screen customization with a bunch of UD fields on the RMA
> > > Dispositions form. Unfortunately, the inspectors call that form from a
> > > button on the lower right of the Inspection Processing screen, which does
> > > not show a MenuID to attach the customization to. Do I have to actually
> > > customize the button somehow to get the scree to show my changes, and if
> > > so, how do I do that?
> > > Thanks,
> > > Ernie Lowell
> > > Diba Industries
9.04.507A SQL.
I've just put a screen customization with a bunch of UD fields on the RMA Dispositions form. Unfortunately, the inspectors call that form from a button on the lower right of the Inspection Processing screen, which does not show a MenuID to attach the customization to. Do I have to actually customize the button somehow to get the scree to show my changes, and if so, how do I do that?
Ernie Lowell
Diba Industries
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Fri, Dec 7, 2012 at 1:17 PM, Elizabeth <gracefulthreads@...> wrote:
> 9.04.507A SQL.
> Thanks,
> Ernie Lowell
> Diba Industries
So far not working.
MenuID:
Called From
MenuID
Ernie
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > 9.04.507A SQL.
> > Thanks,
> > Ernie Lowell
> > Diba Industries
