Customization Questions - Bayesian Filter detected spam
1. I'll look at the append, thank you!
2. What I'm looking for is a continuation of the contact in step 1. Step 1 should be the 'primary' internal contact, this step should be any internal contacts this external contact knows. Any suggestions for the best method of storage? I'm not too concerned about un-concatenating the fields either through Excel ODBC queries or Crystal Reports, but if there's a better method?
I guess the real question is, how do you do a one-to-many relationship through the customization tools? Is UD Tables the best option?
Thanks for the insight,
Ken
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Sean McDaniel
Sent: Monday, June 14, 2010 9:03 PM
Subject: RE: [Vantage] Customization Questions - Bayesian Filter detected spam
1. You should be able to apply the filter within the drop-down
properties. There is an EpiFiltersAppend property for the drop-down. If
you go into sales order entry and look at the "Ship To" -> "Attention"
drop-down you will see an example of this in use.
1. Yes it can be done, but why? Do you not have any UD fields
left? Also, if you store these values within the one field, you have no
way of building BAQ's to pull the individual parts that you are storing
in the one field. You'd need to develop code to concatenate the fields
together and then code to un-concatenate the fields and set the multiple
drop-downs to their correct values.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Ken Williams
Sent: Monday, June 14, 2010 2:51 PM
Subject: [Vantage] Customization Questions
Two simple questions:
1. We've added a customization to Customer Contact tab to select the
internal contact this customer knows best. It draws from the Work Force
adapter. Is there any way of calling this Adapter with an option to
exclude "inactive" people?
2. Is there a tool within customizations that will allow multiple
responses to a single field? Kind of like how it stores "person" in job
entry (Joe~Bob~Glen).
Thanks, as always, for any help,
Ken
1. We've added a customization to Customer Contact tab to select the internal contact this customer knows best. It draws from the Work Force adapter. Is there any way of calling this Adapter with an option to exclude "inactive" people?
2. Is there a tool within customizations that will allow multiple responses to a single field? Kind of like how it stores "person" in job entry (Joe~Bob~Glen).
Ken
Of Ken Williams
Ken
