Customization to allow users to firm release all jobs on an orde
I've taken all the online classes for the technical side but I don't remember anything about this? I'll go back and look at the self-paced courses to see if there's anything.
--- In vantage@yahoogroups.com, robertb_versa@... wrote:
> It's a very simple program (that I've tried to add more poewer to in vain).
> Help explains it well enough.
> If you paid for Vantage training, it was probably briefly mentioned at some point.
> Glad I could help.
> Rob
> --- Original Message ---
> From:"rostamthegrey" <rostamthegrey@...>
> Sent:Mon 12/7/09 8:25 pm
> To:vantage@yahoogroups.com
> Subj:[Vantage] Re: Customization to allow users to firm release all jobs on an order
> Sounds like exactly what I need! Thank You! So I have built a way to retrieve all of the Jobs. I just need to know how to use the job status maintenance? Also, is there a book or knowledgebase that would have helped me to discover the solution to this issue?
> --- In vantage@yahoogroups.com, robertb_versa@ wrote:
> > Why not use job status maintenance (intended for mass firming, engineering and/or releasing)?
> > You can write an advanced search to find all jobs linked to an entered order (and then push firm all).
> > Might not be worth re-inventing the wheel. /:o
> > Rob
> > From:"rostamthegrey" <rostamthegrey@>
> > Sent:Mon 12/7/09 6:58 pm
> > Subj:[Vantage] Customization to allow users to firm release all jobs on an order
> > My problem is, I can use an adapter to get all the rows, but then I can't figure out how to update. I originally tried just using the oTrans OrderRel table. It updates but it only pulls the currently selected job. Below is my code as it stands now. I just need to be able to make it update the data in the database.
> > Private Sub btnConfirm_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnConfirm.Click
> > Dim myDataView As EpiDataView = CType(oTrans.EpiDataViews("OrderRel"), EpiDataView)
> > Dim whereClause As String = "OrderNum = '" + myDataView.dataView(0)("OrderNum").ToString()+ "'"
> > Dim recSelected As Boolean
> > Dim dsSearch As DataSet
> > dsSearch = SearchFunctions.listLookup(oTrans, "OrderRelSearchAdapter", recSelected, False, whereClause)
> > 'MessageBox.Show(dsSearch.Tables(0).Rows.Count.ToString())
> > Dim I As Int32
> > For I = 0 To dsSearch.Tables(0).Rows.Count - 1
> > If btnConfirm.Text = "Confirm" Then
> > dsSearch.Tables(0).Rows(I)("FirmRelease") = True
> > Else
> > dsSearch.Tables(0).Rows(I)("FirmRelease") = False
> > End If
> > Next
> > btnConfirm.Text = "Unconfirm"
> > Else
> > End If
> > End Sub
Dim I As Int32
Else
End If
Next
Else
End If
End Sub
Rob
Dim I As Int32
Else
End If
Next
Else
End If
End Sub
> Rob
> Dim I As Int32
> Else
> End If
> Next
> Else
> End If
> End Sub
Glad I could help.
Rob
> Rob
> Dim I As Int32
> Else
> End If
> Next
> Else
> End If
> End Sub
