Here is a thread I used to get started adding field to collections.
It happens to be the the TimePhase grid.
It might give you some ideas.
You'd need to replace the parentpart with your calculation.
http://tech.groups.yahoo.com/group/vantage/message/106535
--- In vantage@yahoogroups.com, "Winter, Patrick" <pjw@...> wrote:
> I would like to add into the Time Phase Inquiry display grid a
> calculated field that reads the DUE DATE and returns the MONTH number.
> Then I could group on this field and summarize the "Required Qty" and
> "Receipts" columns to show monthly bucket amounts.
> Seems like a great addition to the screen but:
> When I try to Customize the form the "grdList" is just reading the
> TimePhase table and doesn't allow adding a calculated field.
> I thought I would create a BAQ but the TimePhase table is not listed.
> What is the simplest way around this? Is it even possible?
> I found it kinda funny that the "Tips" table is listed in BAQ Designer
> but the "TimePhase" table isn't.
> Patrick Winter
> Testing: Epicor 9.05.607b, Progress Database
