Customizations - Replicating a CheckBox on Another Screen?
Rob, that has worked perfectly. Thanks.
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> I would do a simple FKV and throw a checkbox in and tie it to that..
> zero coding required.
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
> Of CarlH
> Sent: Tuesday, February 22, 2011 1:29 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Customizations - Replicating a CheckBox on
> Another Screen?
> I haven't tested it but I think something like the below would work.
> This woulod be a BPM in the PO.Update.Pre
> Assuming that the check box in the header was CheckBox01
> Basically, it replicates the CheckBox01 from the POHeader in CheckBox 09
> in each PODetail.
> Then you should be able to display this PODetail checkBox on a
> subsequent form.
> find first ttpodetail where ttpodetail.rowmod="U" or
> ttpodetail.rowmod="A" no-lock no-error.
> if available ttpodetail then do:
> FIND FIRST TTPOHEADER WHERE TTPOHEADER.PONum=TTPODETAIL.PONUM NO-LOCK
> NO-ERROR.
> if available ttpoheader then do:
> assign ttpodetail.CheckBox09=ttpoheader.CheckBox01.
> end.
> end.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "ianwhardy" <ianwhardy@> wrote:
> > Hi,
> > I am trying to create a new checkbox on the PO entry screen, and where
> this check box is replicated on the PO Receipt Entry screen (But greyed
> out).
> > However, when it comes to matching the fields, I cannot select
> POHeader from the table list. Can you advise if there is another way to
> do this?
> > It is basically to advise our goods in team wether the part needs a
> material certificate with it on arrival. The check box on PO Entry is
> labelled "Mat Cert?:" and I want the checkbox to pull through on the PO
> Receipt Entry screen, next to a label of "Material Cert Req?:"
> > If you can help, it would be greatly appreciated.
> > Thanks,
Hi,
I am trying to create a new checkbox on the PO entry screen, and where this check box is replicated on the PO Receipt Entry screen (But greyed out).
However, when it comes to matching the fields, I cannot select POHeader from the table list. Can you advise if there is another way to do this?
It is basically to advise our goods in team wether the part needs a material certificate with it on arrival. The check box on PO Entry is labelled "Mat Cert?:" and I want the checkbox to pull through on the PO Receipt Entry screen, next to a label of "Material Cert Req?:"
I haven't tested it but I think something like the below would work. This woulod be a BPM in the PO.Update.Pre
Basically, it replicates the CheckBox01 from the POHeader in CheckBox 09 in each PODetail.
Then you should be able to display this PODetail checkBox on a subsequent form.
find first ttpodetail where ttpodetail.rowmod="U" or ttpodetail.rowmod="A" no-lock no-error.
FIND FIRST TTPOHEADER WHERE TTPOHEADER.PONum=TTPODETAIL.PONUM NO-LOCK NO-ERROR.
end.
end.
--- In vantage@yahoogroups.com, "ianwhardy" <ianwhardy@...> wrote:
> Hi,
> Thanks,
Rob Bucek
FAX: (715)284-4084
Of CarlH
Another Screen?
in each PODetail.
subsequent form.
NO-ERROR.
end.
end.
> Hi,
out).
do this?
> Thanks,
