Customizations - Valid for 4.1.100.0 vs. w4.1.100.0
I’m wondering what the difference in versions means here. Is this a web form version with the ‘w’? I’ve got two customizations for the same form, one is valid for 4.1.100.0 and the other says valid for w4.1.100.0.
What is the difference? Which do both refer to? Checking documentation but not finding the w version # anywhere yet…
Happy Friday!
Check the warnings tab - I believe that is what the w means. usually because some ui object overlaps another ui object’s padding area
Aha! Yes, that does have the warnings. Thank you!
The warnings are all about overlapping, and I’ve tried moving them around to where they do not appear to be overlapping any longer, and visually, they are not, but how important is it to not have these types of cosmetic warnings?
I never worry about it. For UI if everything you expect to see you see, and it looks good, it is good in my book. Overlap is near impossible to get rid of all those errors
I concur. I read somewhere that they aren’t critical, but I wanted to make sure that hasn’t changed. I hate to have any error/warnings at all, but these are a pain.
