Customizatons not saving
Hello,
I’ve been doing some simple development (using 10.1.600.25), applying some customer layer customization to a CSG modification.
Interestingly I can create the customization layer, use the wizard for form load, enter in code and save it the first time, and it works. If I go back into the customization and add to it do an F5 and enter comments and save, but when return back after closing the form the customization code is missing, but the comments remain. The only way I have been able to add to the code is copy out the csharp code, delete the customization and start again.
I have done this with other custom base layers before and adding customizations and adding to them works all the time,
I am really not sure where to begin to try and fix this, and suggestions appreciated.
