Customize Part Duplication form
I stand corrected. It doesn't look like these forms will save any changes(can they?). Maybe I'm doing something wrong here too, but I've tried several things on the part dupe form and when it's reopened, changes vaporized. It's always some kind of wrench in the works!!
So, thank you for your reply! It's much appreciated!!
Kurt
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...> wrote:
> Name the customisation of the sub form the same as the customisation of
> the part maintenance form.
> This should then work for you.
> Regards,
> Stephen
> Of Kurt
> Sent: 21 January 2010 17:01
> To: vantage@yahoogroups.com
> Subject: [Vantage] Customize Part Duplication form
> Hi all,
> I have another project that I'm pretty stuck on. I would like to
> customize the Duplicate Part form....the one that comes up in Part
> Maintenance --> Actions --> Duplicate. I know about the actual
> customization in Developer Mode, but where I'm stuck is trying to do
> like you normally would with a custom form through Menu Maintenance. I
> did save the form as something new, but I'm not sure how to set it live
> to the Part Maintenance form (which is also a custom form) when it's
> done. Like I said, I know how to put out the Part form I'm working on,
> just not the custom dupe form. Any ideas?
> Thanks for your help!!
> Regards,
> Kurt
Hi all,
I have another project that I'm pretty stuck on. I would like to customize the Duplicate Part form....the one that comes up in Part Maintenance --> Actions --> Duplicate. I know about the actual customization in Developer Mode, but where I'm stuck is trying to do like you normally would with a custom form through Menu Maintenance. I did save the form as something new, but I'm not sure how to set it live to the Part Maintenance form (which is also a custom form) when it's done. Like I said, I know how to put out the Part form I'm working on, just not the custom dupe form. Any ideas?
Regards,
Kurt
Regards,
Stephen
Of Kurt
Hi all,
Regards,
Kurt
