Customized SSRS in PILOT, how do I add this as a menu item in PRODUCTION?
I’ve customized an SSRS report in PILOT but now how do I get it to show up as a menu item in PRODUCTION?
I’m guessing you customized an existing report that already has a menu item? Which one is it?
Production Detail Report
In Pilot I can change the report style to see the new report layout but in Production it doesn’t exist.
You need to copy the report over to the Production folder. Are you accessing the report server through a browser?
I’m not accessing the report server at all I don’t think. In class and in my notes I was told that if it asks to connect to the server you answer NO.
So, you download and upload reports through the Report Style screen?
Ok, so I go into Pilot Report style maintenance and download, then go into Production Report Style Maintenance and Upload?
Yes, that is one way to do it.
Okay, what’s the easiest way to do it?
That actually depends. Is your instance on-site, MT, cloud? The answer will be different depending on your particular install.
We are on cloud. The customized report is stored on my local machine.
Doing it through the Report Style is probably the easiest way for you.
