I’m trying to send an email for a certain customer/partnum when “shipped” is checked on the Customer Shipment Entry screen.
On the CustShip.Update pre-processing I check whether ttShipHead.ReadyToInvoice of changed row is = true. If so, I then check for this particular ttShipHead.custnum. If so, I then check for ttShipDtl.partnum. If so, the BPM should fire an email.
Problem, however, is that any time I add the ttShipDtl.PartNum, the email doesn’t fire. If I delete that part and just keep the custnum, I get the email. If I add the partnum, no email.
I’ve tried to add the part number two ways:
“The specified field of the changed row is equal to specified expression”
Number of rows in x query is more than 0.
In both cases, when the ttShipDtl.PartNum is referenced I get no email. I’ve duplicated the query in a BAQ and I get the desired results.
Okay, that would make sense. When I did a trace on clicking the “shipped” checkbox, this method is what was fired. Is there another method that I should consider?
You can run some custom code that can set a variable to true if the PartNum is the same. Then add one more condition to check whether to send the email or not.
The code should look like this:
foreach(var rows in (from row in Db.ShipDtl where
row.Company == Session.CompanyID && row.PackNum == ttShipHead.PackNum select row)){
if (row.PartNum == "Your PartNum"){
SendEmail = true;
You’ll need to create a variable Boolean called SendEmail.
Thanks Ben. For upgrading purposes, I’m trying to stick with the GUI tools as much as possible. The “designed query” feature mentioned above works well.
If I run into an issue where the GUI can’t handle, I’ll check back to this code.
