CutList Report Blank Title 82428
Yup Rob is right Crystal Smart Linking isn't right and even if you think it is the RDD needs to know the added tables and relationships
Sent from my Verizon Wireless BlackBerry
Date: Thu, 3 Sep 2009 12:59:21
To: <vantage@yahoogroups.com>
Subject: RE: [Vantage] CutList Report
First, don't assume crystal linked those tables correctly, most likely,
it did not. Second, you would have also had to add those tables to the
report data definition as well in order to pass any data to the crystal
report itself.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of gmack110256
Sent: Thursday, September 03, 2009 11:23 AM
Subject: [Vantage] CutList Report
I am trying to revamp the Cutlist report. We are in vantage 8.03.403D.
What I am trying to do is bring in the JobAsmbl table and the SubAsmbl
table and link it to the report. I want to be able to add the
Subassembly part number in the report under the material line to show
what part the material is being used for.
When I brought in the tables in Crystal they linked up automatically.
When I try to put in the fields from either of these table into the
report, the report goes blank. I am assuming that there is a problem
with the links somewhere.
Any body got any insight on what I have to do to get these fields to
work in this report?
Thank You
Gene
I am trying to revamp the Cutlist report. We are in vantage 8.03.403D. What I am trying to do is bring in the JobAsmbl table and the SubAsmbl table and link it to the report. I want to be able to add the Subassembly part number in the report under the material line to show what part the material is being used for.
When I brought in the tables in Crystal they linked up automatically. When I try to put in the fields from either of these table into the report, the report goes blank. I am assuming that there is a problem with the links somewhere.
Any body got any insight on what I have to do to get these fields to work in this report?
Thank You
Gene
report itself.
Rob Bucek
FAX: (715)284-4084
Of gmack110256
Thank You
Gene
