Cutomer Customization problem 8.00.811B
Well I narrowed this problem down to when it actually does the upchucking of
the Finance Charge.
financeCharge.checked=false
After some testing many different combinations of the code I narrowed it
down to exactly that line. I even step up a customization to check the Check
Duplicate POs check box, that work fine. Another one to uncheck the Combine
Packing Slips check box, that works fine. It only seems to be the Finance
Charge checkbox that is causing this issue.
Scitt
Scott Litzau
Sent: Tuesday, May 01, 2007 10:45 AM
Subject: [Vantage] Cutomer Customization problem 8.00.811B
I upgraded to 8.00.811B over the weekend and now my customization in
Customer Maintenance is causing a problem where customers can not be
setup.
In my customization I have it set up that when is it is a new
customer then the Finance Charge Check Box is automatically
unchecked. Here is the code
Private Sub Customer_BeforeFieldChange(ByVal sender As object, ByVal
args As DataColumnChangeEventArgs) Handles
Customer_Column.ColumnChanging
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Select Case args.Column.ColumnName
Case "CustID"
If (args.Row("CustID")="") Then 'Is a new Customer
Dim financeCharge As EpiCheckBox = CType(csm.getNativeControlReference
("44fa8a1e-84da-445e-97ee-f0c7526954c0"),EpiCheckBox)
End If
Case Else
End Select
End Sub
Basically what is occuring is that when you enter a new Customer ID
and then Tab out of the field the Cusotmer ID goes blank but yet the
customization still occurs, the finance charge checkbox is unchecked.
I ran Customer Maintenance in Base Mode and everything works fine.
Any suggestions on what can be happening?
Scott Litzau
Yahoo! Groups Links
setup.
Case "CustID"
End If
Case Else
End Select
End Sub
Scott Litzau
Off the top of my head, make sure the EpiGuid did not change for the
control you are getting the reference to.
I got hosed on a couple customizations between 809 and 811 where the
id changed.
Bernie.
--- In vantage@yahoogroups.com, "Scott Litzau" <scott.litzau@...>
in
be
> setup.
ByVal
> Case "CustID"
> End If
> Case Else
> End Select
> End Sub
the
unchecked.
> Thanks,
> Scott Litzau
That was the first thing I checked. It is the same. I actually copied and
pasted it from the Properties just in case.
Scott
bw2868bond
Sent: Tuesday, May 01, 2007 11:12 AM
Subject: [Vantage] Re: Cutomer Customization problem 8.00.811B
id changed.
Bernie.
in
be
> setup.
ByVal
> Case "CustID"
> End If
> Case Else
> End Select
> End Sub
the
unchecked.
> Thanks,
> Scott Litzau
Yahoo! Groups Links
