Cycle Count Auto-Selection Criteria
Parts that are marked inactive will be skipped, yet parts that are on hold will not. Once you pull in the auto-selected parts (which uses ABC codes to calculate), then you should be able to delete individual parts you don't want (i.e. parts on hold).
--- In vantage@yahoogroups.com, Justin Lape <jpl245@...> wrote:
> Does anyone know what factors permanently prevent a part from being pulled in by the auto-selection function for a physical or cycle count such as a part being marked Inactive, Hold status checked, etc? I have several parts in my system that are either marked inactive or are "on hold" or both and I want to know if I need to worry about them showing up in my cycle count auto-selection.
> Thanks in advance.
> Cheers,
> JL
Thanks in advance.
Cheers,
JL
