Cycle Count DMR Warehouse
hi,
yes, every other cycle count in every other plant and warehouse are
working fine. the rest of the warehouses do not have non-nettable
bins, however. i know that i can do a BAQ to easily find materials
there, but finance wants to have system generated cycle count reports
on that warehouse at each plant just like we have for RM or FG
warehouses.
> Amy, another thought...
> I was wondering if you actually did the ABC definitions and
calculations before attempting to do cycle counts.
> Do you have other counts for this plant that are working?
> Carey
> To: vantage@...: rotary1@...: Tue, 23 Sep 2008 12:57:09 -
0500Subject: RE: [Vantage] Re: Cycle Count DMR Warehouse
> I could not guess as to whether Epicor software "cares" about what
is there, but the book says that items located in a non-nettable bin
are excluded from available quantities.But I wonder if there is
something amiss in procedure here. The point of the cycle count is
really to determine how accurate your processes and standards are.
So, if you have a bin of discrepant materials (Do you process DMR in
Vantage?) If you want to get an idea of what parts the system thinks
are located in a bin, you could build a BAQ fairly easily.However,
Cycle counts are really designed about parts, and not so much bins.
So, if you pull a part into the count tag program, and you have 2
bins within the "selected" warehouse in the program, you would
normally get two separate tags, one for each bin in the warehouse.So,
if this is the case, and you have parts located in what you are
labeling as a "DMR bin", and still have stock parts in the primary
regular "available" inventory bin, you should get at least one tag,
regardless if the second bin is non-nettable.It is possible to
literally have every different part in vantage "located" in one
single bin. So, in this case, the tag generation would still be one
tag per part per bin location.You can also pull up the part tracker
and see what shows up in the warehouse locations. This will give you
some idea where to look from a part perspective, and then you can see
what else might be overlooked in the process.CareyTo: vantage@...:
cpsadp@...: Tue, 23 Sep 2008 16:08:44 +0000Subject: [Vantage] Re:
Cycle Count DMR WarehouseThey're regular stock parts. I'm wondering
if this could be a failure to understand either on Epicor's part or
on ours. The bins being non-nettabl would seem to indicate to the
system that you don't care what's there or how many there are, so why
would you cycle count. On the other hand, we actually move parts in
and out and so would want to make sure that we have what we say we
have.amy>> What parts are there?> I do not believe I have attempted
to include non-nettable bins in our counts because they are in a
warehouse that we have not needed to count. Are these parts non-stock
parts? The non-stock parts are not included in the auto-tag
generation during cycle counts. > Carey> > > > To: vantage@: cpsadp@:
Tue, 23 Sep 2008 14:59:52 +0000Subject: [Vantage] Cycle Count DMR
Warehouse> > > > > hi,my finance guy wants all plants to cycle count
the Discrepant Material warehouses. the bins in these warehouses are
non-nettable. when they try to cycle count, no tags will print out,
even if they ask to have zero quantity tags printed. i'm wondering if
this is a function of the bins being non-nettable or if there's
something else going on. anyone?Amy Powell > > > > > >
__________________________________________________________> See how
Windows connects the people, information, and fun that are part of
your life.>
http://clk.atdmt.com/MRT/go/msnnkwxp1020093175mrt/direct/01/> > [Non-
text portions of this message have been removed]>
__________________________________________________________Stay up to
date on your PC, the Web, and your mobile phone with Windows
Live.http://clk.atdmt.com/MRT/go/msnnkwxp1020093185mrt/direct/01/%5bNon-
> _________________________________________________________________
> See how Windows connects the people, information, and fun that are
part of your life.
hi,
my finance guy wants all plants to cycle count the Discrepant Material
warehouses. the bins in these warehouses are non-nettable. when they
try to cycle count, no tags will print out, even if they ask to have
zero quantity tags printed. i'm wondering if this is a function of the
bins being non-nettable or if there's something else going on. anyone?
Amy Powell
I do not believe I have attempted to include non-nettable bins in our counts because they are in a warehouse that we have not needed to count. Are these parts non-stock parts? The non-stock parts are not included in the auto-tag generation during cycle counts.
Carey
To: vantage@yahoogroups.comFrom: cpsadp@...: Tue, 23 Sep 2008 14:59:52 +0000Subject: [Vantage] Cycle Count DMR Warehouse
hi,my finance guy wants all plants to cycle count the Discrepant Material warehouses. the bins in these warehouses are non-nettable. when they try to cycle count, no tags will print out, even if they ask to have zero quantity tags printed. i'm wondering if this is a function of the bins being non-nettable or if there's something else going on. anyone?Amy Powell
See how Windows connects the people, information, and fun that are part of your life.
They're regular stock parts. I'm wondering if this could be a
failure to understand either on Epicor's part or on ours. The bins
being non-nettabl would seem to indicate to the system that you don't
care what's there or how many there are, so why would you cycle
count. On the other hand, we actually move parts in and out and so
would want to make sure that we have what we say we have.
amy
> Carey
> To: vantage@...: cpsadp@...: Tue, 23 Sep 2008 14:59:52
part of your life.
I could not guess as to whether Epicor software "cares" about what is there, but the book says that items located in a non-nettable bin are excluded from available quantities.
But I wonder if there is something amiss in procedure here.
The point of the cycle count is really to determine how accurate your processes and standards are. So, if you have a bin of discrepant materials (Do you process DMR in Vantage?) If you want to get an idea of what parts the system thinks are located in a bin, you could build a BAQ fairly easily.
However, Cycle counts are really designed about parts, and not so much bins. So, if you pull a part into the count tag program, and you have 2 bins within the "selected" warehouse in the program, you would normally get two separate tags, one for each bin in the warehouse.
So, if this is the case, and you have parts located in what you are labeling as a "DMR bin", and still have stock parts in the primary regular "available" inventory bin, you should get at least one tag, regardless if the second bin is non-nettable.
It is possible to literally have every different part in vantage "located" in one single bin. So, in this case, the tag generation would still be one tag per part per bin location.
You can also pull up the part tracker and see what shows up in the warehouse locations. This will give you some idea where to look from a part perspective, and then you can see what else might be overlooked in the process.
Carey
To: vantage@yahoogroups.comFrom: cpsadp@...: Tue, 23 Sep 2008 16:08:44 +0000Subject: [Vantage] Re: Cycle Count DMR Warehouse
They're regular stock parts. I'm wondering if this could be a failure to understand either on Epicor's part or on ours. The bins being non-nettabl would seem to indicate to the system that you don't care what's there or how many there are, so why would you cycle count. On the other hand, we actually move parts in and out and so would want to make sure that we have what we say we have.amy>> What parts are there?> I do not believe I have attempted to include non-nettable bins in our counts because they are in a warehouse that we have not needed to count. Are these parts non-stock parts? The non-stock parts are not included in the auto-tag generation during cycle counts. > Carey> > > > To: vantage@...: cpsadp@...: Tue, 23 Sep 2008 14:59:52 +0000Subject: [Vantage] Cycle Count DMR Warehouse> > > > > hi,my finance guy wants all plants to cycle count the Discrepant Material warehouses. the bins in these warehouses are non-nettable. when they try to cycle count, no tags will print out, even if they ask to have zero quantity tags printed. i'm wondering if this is a function of the bins being non-nettable or if there's something else going on. anyone?Amy Powell > > > > > > __________________________________________________________> See how Windows connects the people, information, and fun that are part of your life.> http://clk.atdmt.com/MRT/go/msnnkwxp1020093175mrt/direct/01/> > [Non-text portions of this message have been removed]>
Stay up to date on your PC, the Web, and your mobile phone with Windows Live.
I was wondering if you actually did the ABC definitions and calculations before attempting to do cycle counts.
Carey
To: vantage@yahoogroups.comFrom: rotary1@...: Tue, 23 Sep 2008 12:57:09 -0500Subject: RE: [Vantage] Re: Cycle Count DMR Warehouse
I could not guess as to whether Epicor software "cares" about what is there, but the book says that items located in a non-nettable bin are excluded from available quantities.But I wonder if there is something amiss in procedure here. The point of the cycle count is really to determine how accurate your processes and standards are. So, if you have a bin of discrepant materials (Do you process DMR in Vantage?) If you want to get an idea of what parts the system thinks are located in a bin, you could build a BAQ fairly easily.However, Cycle counts are really designed about parts, and not so much bins. So, if you pull a part into the count tag program, and you have 2 bins within the "selected" warehouse in the program, you would normally get two separate tags, one for each bin in the warehouse.So, if this is the case, and you have parts located in what you are labeling as a "DMR bin", and still have stock parts in the primary regular "available" inventory bin, you should get at least one tag, regardless if the second bin is non-nettable.It is possible to literally have every different part in vantage "located" in one single bin. So, in this case, the tag generation would still be one tag per part per bin location.You can also pull up the part tracker and see what shows up in the warehouse locations. This will give you some idea where to look from a part perspective, and then you can see what else might be overlooked in the process.CareyTo: vantage@yahoogroups.comFrom: cpsadp@...: Tue, 23 Sep 2008 16:08:44 +0000Subject: [Vantage] Re: Cycle Count DMR WarehouseThey're regular stock parts. I'm wondering if this could be a failure to understand either on Epicor's part or on ours. The bins being non-nettabl would seem to indicate to the system that you don't care what's there or how many there are, so why would you cycle count. On the other hand, we actually move parts in and out and so would want to make sure that we have what we say we have.amy>> What parts are there?> I do not believe I have attempted to include non-nettable bins in our counts because they are in a warehouse that we have not needed to count. Are these parts non-stock parts? The non-stock parts are not included in the auto-tag generation during cycle counts. > Carey> > > > To: vantage@...: cpsadp@...: Tue, 23 Sep 2008 14:59:52 +0000Subject: [Vantage] Cycle Count DMR Warehouse> > > > > hi,my finance guy wants all plants to cycle count the Discrepant Material warehouses. the bins in these warehouses are non-nettable. when they try to cycle count, no tags will print out, even if they ask to have zero quantity tags printed. i'm wondering if this is a function of the bins being non-nettable or if there's something else going on. anyone?Amy Powell > > > > > > __________________________________________________________> See how Windows connects the people, information, and fun that are part of your life.> http://clk.atdmt.com/MRT/go/msnnkwxp1020093175mrt/direct/01/> > [Non-text portions of this message have been removed]> __________________________________________________________Stay up to date on your PC, the Web, and your mobile phone with Windows Live.http://clk.atdmt.com/MRT/go/msnnkwxp1020093185mrt/direct/01/%5bNon-text portions of this message have been removed]
