Hi All,
Is anyone on E9.04 (maybe 9.05 too) that is using the Cycle Count
feature to do Physical Inventories?
If so, is the only way to assign a reason code for an adjustment by
using the Count Discrepancy Reason screen?
In my first test, I posted a Count Cycle without assigning a reason code
and the post went through, which seemed odd because a reason code is
required when doing a quantity adjustment.
I looked at the Inventory/WIP Recon report and only 2 out of the 5 parts
that had adjustments showed up even though there were parttran records
for the parts that didn't show up.
I did another physical inventory but this time I put a reason code
before posting and all adjusted part numbers showed up on the
Inventory/WIP Recon report.
Sounds like a bug. Anyone else seeing this too?
