Cycle count variance approvals
We are implementing cycle counting at several plants and wondering if anyone has come up with a way in the system to approve count variances prior after recounts and prior to posting.
We plan to setup the tolerances to define the variance/recount levels.
I looked at the workflow/tasks and did not see anything there that looked applicable. We have multiple sites and would have a centralized approval. Is this a BPM or UD field?
Curious if anyone else has done this.
Brad
I had a very similar requirement and created a customization on an an updatetable dashboard
The client had an agreed tolerance under which counts could be accepted, they entered he percentage and all the counts falling within the criteria were listed. There was then a ‘Select All’ button that selected everything and allowed the adjustments to be created using standard cycle count functionality.
Thanks for the suggestion.
