Dashboard Assembly location
Hello,
Spent about 10 mins looking around in the app server and could not where this assembly locate in the server. Does anyone knows?
Thanks in advance!
It is stored in DB as a blob (not on the server)
Thanks Jose,
Do you might know what is the table name for the blob?
SELECT
  CAST(DashboardSchema AS XML) AS DashboardXML,
  DashboardAssembly,
FROM Ice.DashBdDef
WHERE DashBdDef.DefinitionID = 'YOURDASHBOARDIDHere'
The DashboardSchema holds Layout data among other things.
The DashboardAssembly is the Assembly, which you probably have to Decode Probably loading it into a MemoryStream using FromBase64String and then adding the stream to a BZip2InputStream among other complicated things.
Thanks a lot !
