Dashboard assembly vs runtime
Under 606 the Runtime splits a field's embedded returns, like Part Description, into multiple rows when copying to Excel whereas the Assembly keeps it intact in one cell.
--- In vantage@yahoogroups.com, "Tom J. Christie" <tchristie@...> wrote:
> An additional note. If you edit a runtime version then the changes are automatic and live. If you use a deployed dashboard, until you redeploy it the production environment is not effected. Of course you could make all the changes in a test environment and then copy it over…
> I only use the deployed ones when I either need it to be updateable or I am throwing a VB customization on the top of the dashboard (custom buttons to pull data or run processes or whatever).
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Rob Bucek
> Sent: Tuesday, July 10, 2012 8:19 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: Dashboard assembly vs runtime
> Thanks all!
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> [Description: cid:1.234354861@...<mailto:1.234354861%40web65412.mail.ac4.yahoo.com>]<http://www.dsmfg.com/>
> (Click the logo to view our site)<http://www.dsmfg.com/>
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mark Wagner
> Sent: Tuesday, July 10, 2012 9:40 AM
> Subject: Re: [Vantage] Re: Dashboard assembly vs runtime
> It used to be if you wanted the Copy All Include Labels ability you had to deploy the dashboard as a DLL versus a runtime. They changed that so now the runtime lets you copy all include labels without deploying as a DLL. Like Jose mentioned, the main reason now is to deploy as an updateable dashboard so when you go into menu maintenance you have to select the option as dashboard assembly, if it is just a dashboard just choose the runtime option
> From: b_ordway <cooner_55421@...<mailto:cooner_55421%40yahoo.com><mailto:cooner_55421%40yahoo.com>>
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Sent: Tuesday, July 10, 2012 10:30 AM
> Subject: [Vantage] Re: Dashboard assembly vs runtime
> A deployed dashboard provides more opportunities for customization and personalization.
> --- In mailto:vantage%40yahoogroups.com, Rob Bucek <rbucek@> wrote:
> > So it appears that dashboards need to be 'deployed' now..whatever that means. What essentially is the functional difference between the runtime version and the assembly version. Why pick one over the other? Thanks for the quick insight
> > Rob Bucek
> > FAX: (715)284-4084
> > [Description: cid:1.234354861@]<http://www.dsmfg.com/>
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
If its an updatable dashboard it needs to be deployed as an assembly.
Otherwise it doesn't matter.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
> the quick insight
> Rob Bucek
> FAX: (715)284-4084
Sweet and succinct! Perfect, thanks my friend.
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Tuesday, July 10, 2012 8:40 AM
Subject: Re: [Vantage] Dashboard assembly vs runtime
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Rob Bucek
> FAX: (715)284-4084
> Rob Bucek
> FAX: (715)284-4084
Â
> Rob Bucek
> FAX: (715)284-4084
Thanks all!
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Mark Wagner
From: b_ordway <cooner_55421@...<mailto:cooner_55421%40yahoo.com>>
> Rob Bucek
> FAX: (715)284-4084
Thanks all!
Rob Bucek
FAX: (715)284-4084
> Rob Bucek
> FAX: (715)284-4084
