I have a dashboard with 4 grids. Each grid have it’s own BAQ and all grid are linked together. When I test it in the Dashboard Maintenance module, it’s working good. If I deployed my dashboard as an assembly, some grids lost their link and the data does not display correctly
@heybigal A couple of questions to aid in understanding. By “linked together” do you mean fields from one BAQ/grid are being published to and received by another? By the data not displaying correctly, is it an incorrect layout, columns not visible when they should be, or the formatting of the data values?
After you deploy the dashboard, have you enabled it on the menu item? Is there a customization?
