Dashboard conversion to Kinetic - XML error
Hi,
I am converting a classic dashboard from 10.2.400 to kinetic 2021.1.7. When I do a Generate preview, I get the following error. I do not know where to look and then fix it. The dashboard has been working in the classic view for many years.
Application Error
Error Detail
Correlation ID: de4ba081-7af1-4299-a0bf-ad854c6650b4
Message: There is an error in XML document (23, 6).
Inner Exception Message: Value was either too large or too small for a signed byte.
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Ice.Proxy.Lib.MetaFXImpl.GenerateView(EpMetaFxGenerateViewRequest request)
at Ice.UI.Dashboard.DashboardAppBuilder.GenerateKineticPreview(DashboardDirector director, Boolean launch)
Inner Exception
Thanks in advance for your help
@Vinaykamboj I’m receiving the same error. Did you get a resolution to this?
For anyone following this thread there is a solution. I submitted a support call on this and was directed to PRB0252263. In my case I had my dashboard refreshing every 5 minutes (300 seconds). In 2022.2.14 a refresh rate greater than 128 returns an error. Setting the refresh rate below 128 then converting the dashboard to Kinetic works. This problem is corrected in later versions.
