Dashboard Error: Object reference not set to an instance of an object
Hi all,
I just recreated this Dashboard. I get this error message when I click the “Shift” key when I customize the tracker view.
The BAQ is fine (i.e. results are OK) and the Dashboard works OK too.
Can anyone explain this error and if/how it can be fixed?
Thanks a lot
Application Error
Exception caught in: Ice.Lib.EpiClientLib
Error Detail
Message: Object reference not set to an instance of an object.
Program: Ice.Lib.EpiClientLib.dll
Method: ParentForm_KeyDown
Client Stack Trace
at Ice.Lib.Customization.CustomToolsDialog.ParentForm_KeyDown(Object sender, KeyEventArgs e)
at System.Windows.Forms.KeyEventHandler.Invoke(Object sender, KeyEventArgs e)
at System.Windows.Forms.Control.OnKeyDown(KeyEventArgs e)
at System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
at System.Windows.Forms.Form.ProcessKeyPreview(Message& m)
at System.Windows.Forms.Control.ProcessKeyPreview(Message& m)
at System.Windows.Forms.Control.ProcessKeyMessage(Message& m)
at Infragistics.Win.EmbeddableTextBoxWithUIPermissions.ProcessKeyMessage(Message& msg)
at System.Windows.Forms.Control.WmKeyChar(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.TextBoxBase.WndProc(Message& m)
at System.Windows.Forms.TextBox.WndProc(Message& m)
at Infragistics.Win.EmbeddableTextBoxWithUIPermissions.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
