Dashboard problem
Thanks for replying.
My filters are in the grid views on the dashboard.
Unfortunately I do not have an Advance Search.
I even recreated the dashboard from scratch and get the same results. It
works fine while still in developer mode, but once I test before deploying,
the filters stop working.
Any help would be appreciated.
Mike
Miguel Santillan
Sent: Tuesday, February 14, 2012 12:37 PM
Subject: RE: [Vantage] Re: Dashboard problem
Are your filters in the query or the dashboard?
Do you have an Advanced Search? If you had an advanced search for the 3
first views and then added the other 9 views, you will need to create the
Advanced Search view. I had this issue as well and that is what fixed my
issue.
Kind Regards,
Miguel A. Santillan
ERP Administrator
Compass Components, Inc.
510-661-6666 Office
510-656-0603 Fax
msantillan@... <mailto:msantillan%40ccicms.com>
<mailto:msantillan@... <mailto:msantillan%40ccicms.com> >
www.ccicms.com<http://www.ccicms.com/>
Behalf Of mike.numbers
Sent: Tuesday, February 14, 2012 8:54 AM
Subject: [Vantage] Re: Dashboard problem
Anyone have any ideas on this?
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com>, "mike.numbers" <mnumbers@...
<mailto:mnumbers@...%3cmailto:mnumbers@...> <mailto:mnumbers@...>> wrote:
> I have a dashboard that originally contained a query with 3 grid views
associated with it. I changed the query by adding an additional field and
added 9 more grid views. Everything looks good while I am in developer mode
and when I get out of developer mode but before I deploy. When I "test" the
dashboard in application builder I get no errors, but my new grid views are
ignoring the filters I set up. The original 3 grid views still work. This is
my first dashboard, so I may be missing something simple, but I don't know
what it is. Anyone have any ideas?
I have a dashboard that originally contained a query with 3 grid views associated with it. I changed the query by adding an additional field and added 9 more grid views. Everything looks good while I am in developer mode and when I get out of developer mode but before I deploy. When I "test" the dashboard in application builder I get no errors, but my new grid views are ignoring the filters I set up. The original 3 grid views still work. This is my first dashboard, so I may be missing something simple, but I don't know what it is. Anyone have any ideas?
Do you have an Advanced Search? If you had an advanced search for the 3 first views and then added the other 9 views, you will need to create the Advanced Search view. I had this issue as well and that is what fixed my issue.
Kind Regards,
Miguel A. Santillan
ERP Administrator
510-661-6666 Office
510-656-0603 Fax
msantillan@...<mailto:msantillan@...>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mike.numbers
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "mike.numbers" <mnumbers@...<mailto:mnumbers@...>> wrote:
