Dashboard retrieve on a button instead of using Refresh on the t
I need to do this, but an updatable dashboard deployed as a DLL, not via
the dashboard runtime. So the method below doesn't work -- no DBTVP
global object.
I tried oTrans.Refresh(), but that gave me the error " is neither a
DataColumn nor a DataRelation for table Results.". (Not a typo...
that's the entire error message).
A trace showed a call to
Epicor.Mfg.BO.DynamicQuery.ExecuteDashBoardQuery, but I can't figure out
what dataset to pass it. Actually, I can't figure out where the dataset
is at all in that form :-(
Any suggestions?
Epicor 9.05.603
Brian.
Of Jose Gomez
Sent: Thursday, March 24, 2011 10:56 AM
Subject: Re: [Vantage] Dashboard retrieve on a button instead of using
Refresh on the tool bar?
I apologize I forgot we need instantiate a static DBTB
//Declare this class level
static Object DBTVP;
//Call this in Init
//You get the DBTVP Number like I mentioned before
DBTVP =
(Object)csm.GetGlobalInstance("DBTVP_218cde09_e9b6_491e_a225_6a9ab8c0ba8
d");
private static void btnFilter_Click(object sender, System.EventArgs
args)
System.Reflection.MethodInfo methInfo =
DBTVP.GetType().GetMethod("RefreshDB",
System.Reflection.BindingFlags.Instance |
System.Reflection.BindingFlags.NonPublic);
if ((methInfo != null))
methInfo.Invoke(DBTVP, null);
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>
<http://www.facebook.com/josegomez>
<http://www.google.com/profiles/jose.gomez>
<http://www.twitter.com/joc85>
On Thu, Mar 24, 2011 at 10:50 AM, Jose Gomez <jose@...>
args)
DBTVP_218cde09_e9b6_491e_a225_6a9ab8c0ba8d.GetType().GetMethod("RefreshD
B",
> The DBTVP is declared hidden, just hit show All code.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> On Thu, Mar 24, 2011 at 10:37 AM, unackvi <unackvi@...> wrote:
>> We have a requirement to have a button on the dashboard tracker
'Retrieve'
>> to get the data after user entered a value in the tracker field.
>> Does anyone know the command I can place on the click event of this
button
>> for the dashboard to get the data like it does when you press the
refresh
>> button on the tool bar?
>> Thanks,
>> Uzma
We have a requirement to have a button on the dashboard tracker 'Retrieve' to get the data after user entered a value in the tracker field.
Does anyone know the command I can place on the click event of this button for the dashboard to get the data like it does when you press the refresh button on the tool bar?
Uzma
private static void btnFilter_Click(object sender, System.EventArgs args)
DBTVP_218cde09_e9b6_491e_a225_6a9ab8c0ba8d.GetType().GetMethod("RefreshDB",
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks,
> Uzma
//Call this in Init
DBTVP =
(Object)csm.GetGlobalInstance("DBTVP_218cde09_e9b6_491e_a225_6a9ab8c0ba8d");
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
>> Thanks,
>> Uzma
Thanks!
I'd let you know if I run into any roadblocks.
> //Call this in Init
> DBTVP =
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> >> Thanks,
> >> Uzma
