Dashboard rules / Image ? 8.03.404a
Thanks guys worked great!
Dan
Of Stephen Edginton
Sent: Monday, July 28, 2008 11:42 AM
Subject: RE: [Vantage] Dashboard rules / Image ? 8.03.404a
Create a Calculated field in the Baq as
Length(table.field)
Then like Rob says use a RowRule.
The correct threshold will require trial and error to determine.
Behalf
Of Robert Brown
Sent: 28 July 2008 17:38
Subject: Re: [Vantage] Dashboard rules / Image ? 8.03.404a
Is the dashboard designed in such a way that you can try applying a
RowRule?
I'd be at a loss for another way.
Rob Brown
--- On Mon, 7/28/08, Dan Shallbetter <dans@...
<mailto:dans%40stateselectric.com>
Subject: [Vantage] Dashboard rules / Image ? 8.03.404a
Date: Monday, July 28, 2008, 11:54 AM
I have a dashboard displaying the operation comment text field. I would
like to highlight the comment text field( or add an image) when the
field length exceeds what is being displayed. Is this possible?
Dan Shallbetter
States Electric Mfg.
Dan Shallbetter
Is the dashboard designed in such a way that you can try applying a RowRule?
Rob Brown
Dan Shallbetter
Length(table.field)
Of Robert Brown
RowRule?
Rob Brown
Dan Shallbetter
