Dashboard Subquery Criteria
I have a dashboard with several tabs. Where we are trying to get all of the quotes that are between 10,000 and 19,999 on one, all quotes that have certain task id’s.
I created a calculated field to get the sum for the total amount that should let me get values between the two totals.
Then did a SubQuery Criteria with having.
The issue I’m having is when I put the SubQuery Criteria on the BAQ it doesn’t pull all of the quotes back.
Here is the BAQ with the SubQuery Criteria.
Here is the BAQ without the SubQuery Criteria, its the only thing I removed. Quote number 325794 should show up on the BAQ. If you total all three lines it’s 13,786.
Summary
select
	[QuoteDtl].[QuoteNum] as [QuoteDtl_QuoteNum],
	[QuoteDtl].[ProdCode] as [QuoteDtl_ProdCode],
	[QuoteHed].[ChangedBy] as [QuoteHed_ChangedBy],
	[QsalesRP1].[QSalesRP_Name] as [QSalesRP_Name],
	[TaskSet].[TaskSet1_TaskSetDescription] as [TaskSet1_TaskSetDescription],
	[Tasks].[Task_Conclusion] as [Task_Conclusion],
	[Tasks].[Task_ReasonCode] as [Task_ReasonCode],
	[QuoteCnt].[Name] as [QuoteCnt_Name],
	[QuoteHed].[EntryDate] as [QuoteHed_EntryDate],
	[QuoteHed].[DueDate] as [QuoteHed_DueDate],
	(QuoteHed.EntryDate) as [Calculated_enddate],
	(sum((QuoteDtl.OrderQty  * QuoteDtl.DocExpUnitPrice) - QuoteHed.DocTotalDiscount)) as [Calculated_total]
from Erp.QuoteDtl as QuoteDtl
inner join Erp.QuoteHed as QuoteHed on
	QuoteDtl.Company = QuoteHed.Company
	and QuoteDtl.QuoteNum = QuoteHed.QuoteNum
	and ( QuoteHed.QuoteClosed = 0  )
left outer join Erp.QuoteCnt as QuoteCnt on
	QuoteHed.Company = QuoteCnt.Company
	and QuoteHed.QuoteNum = QuoteCnt.QuoteNum
inner join  (select
	[QSalesRP].[Name] as [QSalesRP_Name],
	[QSalesRP].[Company] as [QSalesRP_Company],
	[QSalesRP].[QuoteNum] as [QSalesRP_QuoteNum]
from Erp.QSalesRP as QSalesRP)  as QsalesRP1 on
	QuoteDtl.Company = QsalesRP1.QSalesRP_Company
	and QuoteDtl.QuoteNum = QsalesRP1.QSalesRP_QuoteNum
inner join  (select distinct
	[Task].[Company] as [Task_Company],
	[Task].[Key1] as [Task_Key1],
	[Task].[Conclusion] as [Task_Conclusion],
	[Task].[ReasonCode] as [Task_ReasonCode],
	[Task].[TaskDescription] as [Task_TaskDescription],
	[Task].[TaskSetID] as [Task_TaskSetID]
from Erp.Task as Task
where (Task.RelatedToFile = 'QuoteHed'  and Task.Complete = 0  and Task.TaskID in ('CSFU1', 'CSFU2', 'CSFU3', 'CSFU4', 'CSFUL1', 'CSFUL3')))  as Tasks on
	QuoteDtl.Company = Tasks.Task_Company
	and QuoteDtl.QuoteNum = Tasks.Task_Key1
inner join  (select
	[TaskSet1].[Company] as [TaskSet1_Company],
	[TaskSet1].[TaskSetID] as [TaskSet1_TaskSetID],
	[TaskSet1].[TaskSetDescription] as [TaskSet1_TaskSetDescription]
from Erp.TaskSet as TaskSet1)  as TaskSet on
	Tasks.Task_Company = TaskSet.TaskSet1_Company
	and Tasks.Task_TaskSetID = TaskSet.TaskSet1_TaskSetID
group by [QuoteDtl].[QuoteNum],
	[QuoteDtl].[ProdCode],
	[QuoteHed].[ChangedBy],
	[QsalesRP1].[QSalesRP_Name],
	[TaskSet].[TaskSet1_TaskSetDescription],
	[Tasks].[Task_Conclusion],
	[Tasks].[Task_ReasonCode],
	[QuoteCnt].[Name],
	[QuoteHed].[EntryDate],
having (sum((QuoteDtl.OrderQty  * QuoteDtl.DocExpUnitPrice) - QuoteHed.DocTotalDiscount)) >= 10000  and (sum((QuoteDtl.OrderQty  * QuoteDtl.DocExpUnitPrice) - QuoteHed.DocTotalDiscount)) <= 19999
Wouldn’t it be better to filter the data on the dashboard vs the BAQ. That way you can reuse the BAQ for all of the tabs.
I just tried that and its not working either. Its pulling in Quotes that have zero or less than 10000.
{F6D6D6B5-17A9-4D84-B6A4-91C5DBBBB5E8}
{3E8A2E3C-34FC-456B-B5F9-09D9638B5CE9}
This is the calculated field
{8D873B31-E086-484B-87BC-A0BB4CFDE0C9}
I’m sure its something stupid that I’m missing :frowning:
You are on the Row Rule tab. You would want to be on the Filer Tab.
