Dashboard to filter data that CONTAINS the contents of a textbox
Make Sure the DashboardCondition of the textbox properties is set to
Matches
Use * before and after the text to search on.
bw
--- In vantage@yahoogroups.com, "lapulsifer" <sharon.pulsifer@...>
wrote:
> Hello, I am new to Vantage 8.03.305h. We run in a SQL Server 2005
> environment.
> I have created a BAQ that I put on a dashboard. I need to add a text
> field to the dashboard that will be used to filter information. I
have
> this working in the case of an exact match or a match to the
beginning
> of the data.
> How can I make this work for a filter where the data contains the
> contents of the Text box? I must be missing something important.
> I hope that I have provided enough information. Thanks for your help.
environment.
field to the dashboard that will be used to filter information. I have
this working in the case of an exact match or a match to the beginning
of the data.
I know Progress uses the 'INDEX' Function ( Source as CHAR, Target as CHAR, Starting-point as Integer) , starting point defaults to beginning of Source string: Returns an Integer depicting 'starting-point' of Target string within Source string : I'm guessing a '0' is returned if 'Target' not found
lapulsifer <sharon.pulsifer@...> wrote: Hello, I am new to Vantage 8.03.305h. We run in a SQL Server 2005
environment.
of the data.
Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel and lay it on us.
