Hello All,
In your experience is it better to customize the dashboard tracker UI in the dashboard before deploying it as an assembly or after??
Utah
Hello All,
Utah
I prefer to create a customization on the dashboard (after deploying).
The main reason is that you can create different versions of the customization (V01, V02, etc.) so that you can revert back to a previous version if there is any problem. You can’t do that with the “Customize Tracker View” option.
Also the positions of the controls is buggy when using “Customize Tracker View”, all the controls keep moving from time to time. I get better control of the layout with customizations.
Interesting - I never thought to create a customization on a dashboard (that I created). I have been just modifying the dashboard itself.
Thanks Mathieu, I think I will re-deploy.
I don’t mind using the embedded tracker controls though, but I’ll leave the customization all on one layer and just customize the click events and what not using a customization.
@jimship exactly… that’s why I ask. I figured most would agree with Mathieu.
