Dashboard Tracker Not Working
Hi,
I am definately searching for valid info.
Sent: Thu, 24 March, 2011 14:31:32
Subject: [Vantage] Re: Dashboard Tracker Not Working
Â
Do you know for sure that the BAQ will bring any data for the value you provided
in the ResourceID?
If there are no records that meet the criteria you won't see the dashboard do
anything.
You can verify this by going into your BAQ and placing a condition on your
ResourceID with the same value you provided in the dashboard and run the BAQ to
see if you get results.
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> I have created a simple BAQ ...
> ÂÂ
> ECORev < ECOOpr < ECOOpDtl
> ÂÂ
> I have just taken the standard joins that are given when you pull in the
>tables.
> ÂÂ
> I have then pulled the BAQ into the Dashboard and added a tracker on
> ECOOpDtl.ResourceID.
> ÂÂ
> When I test the dashboard and select a ResourceID in the tracker, nothing comes
> up in the results of the Dashboard.
> ÂÂ
> I have left the ResourceID blank and still nothing comes up.
> ÂÂ
> I seem to be hacing a lot of trouble with trackers on 9.04.505c where they
>don’t
> work, but I don’t think I am doing anything different (or wrong) and they
>used
> to work ok on 503b.
Â
Â
I have just taken the standard joins that are given when you pull in the tables.
Â
Â
Â
Â
I seem to be hacing a lot of trouble with trackers on 9.04.505c where they don’t
work, but I don’t think I am doing anything different (or wrong) and they used
to work ok on 503b.
Do you know for sure that the BAQ will bring any data for the value you provided in the ResourceID?
If there are no records that meet the criteria you won't see the dashboard do anything.
You can verify this by going into your BAQ and placing a condition on your ResourceID with the same value you provided in the dashboard and run the BAQ to see if you get results.
> ÂÂ
> ÂÂ
> ÂÂ
> ÂÂ
> ÂÂ
> ÂÂ
> to work ok on 503b.
