I have a dashboard that I have added a simple view rule to highlight a field based on its value. Seems to work fine, but if I run it from Dashboard Maintenance I get the error below. Anyone know what would cause this… and do I care since it works fine? Notes:
- Running it from Dashboard Maintenance seems to be the only time it generates the error
- It doesn’t appear to matter what field I choose to apply the rule to, it generates the error
- I have dashboards based on other queries with view rules that do not generate the error
- I redeployed and get the same error
- I created another dashboard using the same query and get the same error
- Running version 2021.2.23 on-premises
Application Error
Exception caught in: Ice.Lib.EpiClientLib
Error Detail
Message: Control ‘myGrid’ of type EpiUltraGrid has an invalid binding to view V_ST_Shop_OPS_DateRange_1View1.
Program: Ice.Lib.EpiClientLib.dll
Method: EventSetup
Client Stack Trace
at Ice.Lib.Framework.EpiUltraGrid.EventSetup()
at Ice.Lib.Framework.EpiUltraGrid.set_EpiTransaction(IEpiTransaction value)
at Ice.Lib.Framework.EpiUIUtils.BindNConfigureControls()
Thanks!
