I have a deployed dashboard that stopped working yesterday. The dashboard is made up of two UBAQs with custom actions. It was working fine last week. Today it is not returning any data in the grids. The underlying BAQs work just fine. When I preview it in Application Studio both grids return data. But as soon as it is published, the grids return no data. In my research, ExecuteBaq runs in preview mode, but not in live published mode. What did they screw up this time? ![]()
Is there any grouping applied?
Yes, ideally there is, but even without grouping I cant get any results.
Well there is an accepted PRB for provider model with grouping not getting any results. If it truly has no groups (which can be hard to see if you have no results) than it sounds like you will need a separate case and PRB and/or PM or email your case to Tracy
Sure enough. I turned off the grouping and my dashboard returns results. Thank you! I’ll hold my breath until this one gets fixed… ![]()
