We are on 9.05.700C
This is a new message to me. The dashboard that this cam from opened OK and works. Any suggestions as to the cause of this error message?
- Neil
Error Detail
Data at the root level is invalid. Line 1, position 1.
Stack Trace
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace()
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlReader.MoveToContent()
at System.Data.DataSet.ReadXml(XmlReader reader, XmlReadMode mode, Boolean denyResolving)
at System.Data.DataSet.ReadXml(String fileName, XmlReadMode mode)
at Epicor.Mfg.UI.FrameWork.FormFunctions.ReadDataSet(Object Sender, DataSet ds, String FileName, String Type, XmlReadMode mode, String& FilePath)
at Epicor.Mfg.UI.Customization.CustomLayeringManager.LoadCustomizationPersonalization(String custLayerInfoName, String custFileName)
