Data Collection Bar Codes (6.1) BAR Code for Receiving?
Along the lines of Bar Coding, has anyone set up to do any other
data entry in Vantage using Bar Codes, i.e. Receiving or Inventory
movements? I thought some were using the AMM module to accomplish
this or at least assist with accomplishing this?
Joy Fekkes
Jaco, Inc
508-553-1040
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@...> wrote:
> Rich,
> Ok, here is how to set it up.
> You need to have your barcode scanner enabled for Code39 extended
or full
> ASCII.
> You then need to have a barcode that has these components:
> * = Start and Stop (begin and end all barcodes with this)
> $M = Enter
> $I = Tab
> Then appropriate keyboard shortcuts to get the job done.
> For instance. Log in:
> *123$M$M$M$M*
> Start, empid, enter to accept, enter to accept shift, enter to OK
shift
> window, enter to activate Log In/Out, end.
> The same principle can be applied to log into and out of job.
> I modified the traveler to include the following barcode for each
operation.
> IIF ({JOBOPER.BCOPRSEQ} > "" and {@OperVendor} = "",
> "*" & Trim ({JOBOPER.JOBNUM}) & "$M" & Trim ({JOBOPER.ASMSEQ})
& "$M" & Trim
> ({JOBOPER.OPRSEQ}) & "$M" & "$M" & "*"
> This single barcode will scan from the Start Activity screen after
selecting
> Production (or Setup, Rework...).
> It enters the Job Number, enter to get to assm field, then Assm
Seq, then
> enter to move to next field, then Op Seq, then two enters to
accept and ok
> the screen.
> I highly recommend combining barcodes with touch screens. It
makes Data
> Collection quick and painless.
> If this is to detailed, sorry, but I wanted to make sure you had
the tools
> to continue this as desired.
> Good luck,
> Aaron Hoyt
> Vantage Plastics
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
Behalf
> Of RICH WAGNER
> Sent: Tuesday, February 14, 2006 8:13 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Data Collection Bar Codes (6.1)
> How are you setting up your barcodes? Do you have a single
barcode to
> clock you in or do you have multiple barcodes the employee must
scan?
> How about starting an activity, what is you scanning sequence? I
would
> want our office employees who only clock in and out to start and
end
> their day to be able to just scan a single barcode to clock in and
out.
> I want to keep it simple as possible for starting an activity, but
I
> thinking this will require multiple scans one for the employee
number
> and others for Job Number, Assembly and Operation. I am curious
of how
> other are able to accomplish this.
> I look forward to your response.
> Thanks
> Rich
> _____
> From: Aaron Hoyt [mailto:aaron.hoyt@...]
> Sent: Monday, February 13, 2006 8:32 AM
> Richard,
> Typically when trying to do this, I will tab "$I" to a button and
then
> send
> an "O". Most screens in data collection use O to replace Ok.
> Alternatively
> you can use "$M" enter to accept data in most fields and then
again to
> accept the form in many forms.
> Although not exactly the answer your question, I hope this helps
point
> you
> in a direction.
> Good luck,
> Aaron Hoyt
Behalf
> Of Richard Bailey
> Sent: Monday, February 13, 2006 4:59 AM
> To: UserGroup
> Subject: [Vantage] Data Collection Bar Codes (6.1)
> I'm trying to define some bar codes to replicate key strokes to
make our
> shop users life (even) easier when they use Plant Floor.
> For example I've got one to start direct production activity
defined as
> "*%DA%DP*", i.e. Alt-A, Alt-P, and it works fine. The problem I
have is
> in
> replicating the F2 keystroke (ie OK, Save etc). I'm using "*$B*"
but
> when I
> scan this nothing happens. I'm using a Wasp CCD scanner set to
read Code
> 39
> as Full ASCII with no automatic terminator (CR etc) and the
DataWorks
> Bar39
> symbology.
> Does anyone have any ideas or examples that they are willing to
share?
> Thanks
> Regards,
> Richard
> Richard Bailey
> Dudley Industries
> Mailto: rbailey@...
> Tel: +44(0)1253 738311
> Mob: +44(0)7836 550360
> Fax: +44(0)870 7628173
I'm trying to define some bar codes to replicate key strokes to make our
For example I've got one to start direct production activity defined as
"*%DA%DP*", i.e. Alt-A, Alt-P, and it works fine. The problem I have is in
replicating the F2 keystroke (ie OK, Save etc). I'm using "*$B*" but when I
scan this nothing happens. I'm using a Wasp CCD scanner set to read Code 39
as Full ASCII with no automatic terminator (CR etc) and the DataWorks Bar39
symbology.
Does anyone have any ideas or examples that they are willing to share?
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
Richard,
Typically when trying to do this, I will tab "$I" to a button and then send
an "O". Most screens in data collection use O to replace Ok. Alternatively
you can use "$M" enter to accept data in most fields and then again to
Although not exactly the answer your question, I hope this helps point you
in a direction.
Good luck,
Aaron Hoyt
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Richard Bailey
To: UserGroup
symbology.
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
Yahoo! Groups Links
How are you setting up your barcodes? Do you have a single barcode to
clock you in or do you have multiple barcodes the employee must scan?
How about starting an activity, what is you scanning sequence? I would
want our office employees who only clock in and out to start and end
their day to be able to just scan a single barcode to clock in and out.
I want to keep it simple as possible for starting an activity, but I
thinking this will require multiple scans one for the employee number
and others for Job Number, Assembly and Operation. I am curious of how
Rich
_____
Richard,
send
Alternatively
you
in a direction.
Good luck,
Aaron Hoyt
Of Richard Bailey
To: UserGroup
in
when I
39
Bar39
symbology.
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
have
and
Yahoo! Groups Links
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
_____
Rich,
You need to have your barcode scanner enabled for Code39 extended or full
ASCII.
$M = Enter
$I = Tab
*123$M$M$M$M*
Start, empid, enter to accept, enter to accept shift, enter to OK shift
I modified the traveler to include the following barcode for each operation.
"*" & Trim ({JOBOPER.JOBNUM}) & "$M" & Trim ({JOBOPER.ASMSEQ}) & "$M" & Trim
This single barcode will scan from the Start Activity screen after selecting
It enters the Job Number, enter to get to assm field, then Assm Seq, then
enter to move to next field, then Op Seq, then two enters to accept and ok
the screen.
I highly recommend combining barcodes with touch screens. It makes Data
If this is to detailed, sorry, but I wanted to make sure you had the tools
Good luck,
Aaron Hoyt
Vantage Plastics
Of RICH WAGNER
Rich
_____
Richard,
send
Alternatively
you
in a direction.
Good luck,
Aaron Hoyt
Of Richard Bailey
To: UserGroup
in
when I
39
Bar39
symbology.
Regards,
Richard
Richard Bailey
Dudley Industries
Mailto: rbailey@...
have
and
Yahoo! Groups Links
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
Yahoo! Groups Links
