I thought of trying to make this report a BAQ, but The SubAmsbl Table is not
anything i can bring into a BAQ. It is not a choice when building the BAQ.
Is there a way to convert it directly into a BAQ?
Gene
Gene
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Convert it to a BAQ Report.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> *Quis custodiet ipsos custodes?*
> On Mon, Mar 21, 2011 at 8:14 AM, gmack110256 <genemack@...>wrote:
> > I have created a new Data definition in Vantage 8.03. It was ctreated from
> > the Job Traveler definition. I have created a new Crystal report from this.
> > If i tie it to the job traveler as a report style it will work just fine.
> > My question is this. I wnat to be able to set this up so it can be used as
> > a stand alone report. Right now when I access it under the Job Travler uses
> > the selection screen that the travler is tied to to run and filter the
> > report ( as it should). What I wouldlike to do is use different selection
> > screen to run this report on.
> > When I try to put it in uder menu maintance I see that the Job Travler is
> > using Epicor.Mfg.UIRpt.JobTrav.dll to run the report.
> > I can't figure out how to tie it to a something different to be able to
> > setup a new selection Screen.
> > Can anyone steer me in the right direction as to what to look for or is
> > this not possible.
> > Thank You
> > Gene
