Hi All,
Wondering if anyone has had any success writing an SSRS report to an Azure File Share?
I have tried setting up a Data Directive on SysRptLst that picks up when a report is run, then outputs to a csv file. This is the code;
int reportStyle = 1001;
string printProgram = @"Reports/CustomReports/*report name*";
var reports = (from row in ttSysRptLst
where (row.PrintProgram == printProgram )
//&& row.RptNote.Contains(key) )
select row).ToList();
foreach(var report in reports)
string SelCompany = callContextClient.CurrentCompany.ToString();
string SelPlant = callContextClient.CurrentPlant.ToString();
string FName = SelCompany + SelPlant + "TimePhase" + DateTime.Now.ToString("yyyyMMdd");
string fileName = @"\\*azure fileshare name*" + string.Format(@"{0}.csv",FName);
byte[] bytes = ((byte[])report.RptData);
using(var svc = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.FileTransferSvcContract>(Db))
svc.UploadFile(Epicor.ServiceModel.Utilities.SpecialFolder.UserData, FName, bytes);
The code seems to work but I am getting an authorization error on the file share. I think I am missing something to do with authenticating to the Azure share. Iām not sure how to do this, anyone done something similar?
