Hi Friends;
Eagerly waiting for a solution for the below problem.
Regards
Sreejith J
Sent: Mon, April 4, 2011 12:20:49 PM
Subject: Re: [Vantage] Data loss after Journal Voucher Posting
Hi Friends;
As a solution for the doubt raised by me I tried doing the below procedure but I
was not successful. Kindly please help me to sort out the issue
01. Customized the Journal Entry Transaction. Created a text field to enter the
JV Reference number. Assigned the datasource as GLJRNHED.CHARACTER01
02. Created a method directive GLJournalEntry.Update
03. Created a new PRE-PROCESSING
CONDITION is - the GLJrnHed.Character01 field of the changed row is not equal to
the "" value
ACTION is set the GLJrnDtl.Character01 field of the changed row to the
"ttGLJrnHed.Character01" value
After setting the above said when I did the Journal Entry I found that the
Reference number I am mentioning on the GLJRNHED.CHARACTER01 is not getting
written to GLJrnDtl.Character01.
I tried the same with POST-PROCESSING also bu the result was the same.
I hope that I had been clear to explain my problem. Any help for the above would
be highly appreciable.
Regards
Sreejith J
Sent: Tue, March 29, 2011 6:43:23 PM
Here is the description of the table in data dictionary:
GLJrnHed
General Ledger Journal Entry Header. This is Parent file to the GLJrnDtl.
These records are only created/used by the G/L journal entry programs. They
are deleted during the posting process.
so i guess no choice but to store them in GLJrnldtl
Ephraim
On Tue, Mar 29, 2011 at 10:25 AM, Sreejith Jaganathan <
sreesvantagedoubts@...> wrote:
Regards
Sreejith J
Hi Friends;
the "" value
Regards
Sreejith J
GLJrnHed
Ephraim
> First of all I would like to thank Mr. Ephraim Feldman and Ms. Linda to
> answer
> my query.
> Initially the key field property was set as FALSE. After receiving your
> mail I
> changed it and tested the transaction but still I didn't find the posting
> being
> done for the value entered in the customized field.
> I am also trying the way suggested by Mr. Ephraim Feldman. Hope to get
> thru. If
> there is any easy way then please do let me know.
> Regards
> Sreejith J
> From: Linda Lowney <llowney@...>
> Sent: Tue, March 29, 2011 5:49:12 PM
> Subject: RE: [Vantage] Data loss after Journal Voucher Posting
> Did you set the Key Field property to true?
> Of Sreejith Jaganathan
> Sent: Tuesday, March 29, 2011 8:06 AM
> To: Vantage Group
> Subject: [Vantage] Data loss after Journal Voucher Posting
> Hi Friends;
> Any help for the below said. The help is required very badly.
> Regards
> Sreejith J
> Hello Friends;
> I am facing a problem with JV Postings. Let me explain what I did
> I customized the JV Entry form. I created a new label (Text on the label
> is [ACC
> REF NUMBER]) and a text box. The data source for the text box was given
> as
> GLJournalHed and the data field as CHARACTER01.
> When the data entry is done in the JE transaction I observed that the
> data
> entered in the customized field is correctly getting stored but after
> the
> posting I am not able to find the data entered by me in the customized
> field.
> I was not able to trace out where the data has gone. Could any body
> please let
> me know what to do in order to track down the data or get it posted
> correctly
> with all the data entered initially.
> Regards
> Sreejith J
