Data migration into Vantage
Thats what we did - saved quite a few thousands of dollars in import
fees. See some samples I've posted here - turn on tracing in vantage -
use full dataset logging - see which values are getting sent to
business objects and make the same calls. to get started search for
some of my posts - all objects follow roughly the same format
including po.
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@...> wrote:
> Another option is written VB.Net standalone programs to populate the
> documents. You're using the same interface that the client does, so
you're
> business rules are enforced. However, you won't get help from
Epicor and it's
> undocumented. I just ran a trace in the client and watched which
objects were
> called with which parameters.
> How many open purchase orders do you have? Is it really too much to
do by
> hand? It's good practice...
> Mark W.
Hello All,
We are in the process of planning our Pilot for Vantage 8.03, but am
having problem loading outstanding Purchase Orders from our existing
system into Vantage. I've managed to extract the data into a .csv
file, but that's as far as i got. Epicor has not been of much help in
all of these, so I am enquiring, how did you manage to migrate your
data into Vantage? Any suggestions on how to go about this (other
than typing everything in manually!!!!)????
your advices would be much appreciated.
kind regs
Anthony Chung
Implementation Manager
Westone Products
I don't think you can cut and paste for Purchase Orders. Since there is
a header, lines, releases, and misc charges all in different tables, it
doesn't lend itself to a flat file format. Some things you are just
going to have do manually through the interface.
Of wplvantage
Sent: Tuesday, April 24, 2007 10:00 AM
Subject: [Vantage] data migration into Vantage
Hello All,
kind regs
Anthony Chung
Westone Products
This is an e-mail from Saab Barracuda LLC. It is for the intended recipient only and may contain confidential and privileged information. No one else may read, print, store, copy, forward or act in reliance on it or its attachments. If you are not the intended recipient, please return this message to the sender and delete the message and any attachments from your computer. Your cooperation is appreciated.
This message has been scanned by F-Secure Anti-Virus for Microsoft Exchange.
For more information, connect to http://www.f-secure.com/
You can only "cut & paste" where there is a "list" panel.
Someone on this list recommended MacroExpress to load V8 panels.
I am doing this with customers and parts, but (not being an expert)
there is much trial and
error to get the program to work right. The premise is the same, you
take
your excel dataset as your input document and use MacroExpress to copy
to vantage and
move to the next field or tab or whatever. The program is around $30.
good luck.
<http://geo.yahoo.com/serv?s=97359714/grpId=20369/grpspId=1705007183/msg
Id=56502/stime=1177424293/nc1=4507179/nc2=3848547/nc3=3848642>
documents. You're using the same interface that the client does, so you're
business rules are enforced. However, you won't get help from Epicor and it's
undocumented. I just ran a trace in the client and watched which objects were
How many open purchase orders do you have? Is it really too much to do by
Mark W.
There are macro programs designed to emulate keypunching. GroundControl
by Acrasoft is one I have used to do plenty on 6.1 and it is very
simple.
Good luck!
Mario E. Aguirre - IT Manager
Of wplvantage
Sent: Tuesday, April 24, 2007 9:00 AM
Hello All,
kind regs
Anthony Chung
Westone Products
