C:\Users\cbarron\AppData\Local\Temp\Epicor\DataModelGenerator\Source\Server\Db\Ice.Data.Model\IceContext.Model.cs(1946,17): error CS0234: The type or namespace name ‘UD30’ does not exist in the namespace ‘Ice.Tables’ (are you missing an assembly reference?)
C:\Users\cbarron\AppData\Local\Temp\Epicor\DataModelGenerator\Source\Server\Db\Ice.Data.Model\IceContextImpl.cs(73,13): warning CS0618: ‘IceContextImpl.IceContextImpl(EntityConnection)’ is obsolete: ‘Not compatible with Entity Framework Core.’
C:\Users\cbarron\AppData\Local\Temp\Epicor\DataModelGenerator\Source\Server\Db\Ice.Data.Model\IceContext.Model.cs(1962,51): warning CS0618: ‘IceDataContext.IceDataContext(EntityConnection)’ is obsolete: ‘Not compatible with Entity Framework Core.’
C:\Users\cbarron\AppData\Local\Temp\Epicor\DataModelGenerator\Source\Server\Db\Ice.Data.Model\IceContextImpl.cs(78,13): warning CS0618: ‘IceContextImpl.IceContextImpl(EntityConnection, bool)’ is obsolete: ‘Not compatible with Entity Framework Core.’
Error Generating the Data Models: Unable to build Data Model ‘Ice.Data.Model’.
While we could probably wade through that and figure out where you went wrong, it would be much easier if you asked a question, showed what you’ve done, and what you’re trying to do.
If you don’t speak English, Spanish is fine.
We’ll sort it out.
Encontre el error. Por alguna rara razón no me deja agregar columnas a la tabla UD30, solo elimine esa columna y todo esta bien ahora
Gracias!
Hurra
