On Wed, Aug 26, 2015 at 2:56 PM, mseal@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>thanks Jose - would you know details of possible issue and what i should be looking for?</p><div>thanks</div><div>motty</div><div><br></div><p></p> </div><span> <div style="color:#fff;min-height:0;"></div>
Epicor 10.0.700.2
I plan to have 2 app servers on a single Windows server pointing to two Epicor dBs
The UD table structure will be different on the 2 dBs
Question/concern – when generating the data module in Epicor, Epicor seems to build the data schema using the Erp.Data.910100.dll file – this file is generated on the C: drive under:
C:\Program Files (x86)\Common Files\Epicor Software Corporation\Database Manager Extensions\3.0.7\DataModelGenerator\Deployment
Seems like file gets copied over the IIS app directory after generation – wonder if that may cause issues as schema is different between app servers
Motty
On Wed, Aug 26, 2015 at 2:20 PM, mseal@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p class="ygrps-yiv-1807714764MsoNormal">Epicor 10.0.700.2</p><p class="ygrps-yiv-1807714764MsoNormal">I plan to have 2 app servers on a single Windows server
file – this file is generated on the C: drive under:C:\Program Files (x86)\Common Files\Epicor Software
Corporation\Database Manager Extensions\3.0.7\DataModelGenerator\DeploymentSeems like file gets copied over the IIS app directory after generation – wonder if
that may cause issues as schema is different between app serversThanks
Motty
</div> <div style="color:rgb(255,255,255);min-height:0px;"></div>
