I am stuck at step 4.9 on the Data Utility guide. When I try to run the Schema Change, I get and error that reads:
"Database not in sync with Program. Database (9.05.700) Program (9.04.508). Cannot continue.â€
I'm a little confused on this step, if I take a look at previous steps, 4.3 had me install the Utility components for 9.05 and I did select the location of the mfgsys.db file that is our database file, did it get upgraded to 9.05 at this step and so I can skip this schema change step? I want to be sure before moving on.
Anyone run into something similar?
Larry Jedik
