Database maintenance
Get more disk..Lots of luck. Our 8 Gig 8.03 SQL Db became 13 Gig in our
non-functional 9.05 test instance.
Robert Carlson
Flanagan Industries
bcarlson@...
sanfranc415
Sent: Friday, July 09, 2010 4:33 PM
Subject: [Vantage] Database maintenance
Our Vista OpenEdge 10.1B database with Progress is now 4.8GB
The size has increase dramatically in the last 1-year, probably 2GB. I
realize there are a bunch of commands in the oe101b\bin directory for
maintenance like the proutil command.
What would the group recommend?
Regards,
--sf
The size has increase dramatically in the last 1-year, probably 2GB. I realize there are a bunch of commands in the oe101b\bin directory for maintenance like the proutil command.
Regards,
--sf
2GB is a lot to add unless you are doing a lot of transactions. Are you using the Change Log? You can accumulate a lot of change log records if you are not careful especially if you are running MRP.
The best way to compact the database is with a dump and load. If you have a decent server a dump and load for your size database could easily be done in 3 to 4 hours or less.
Charles Carden
IT Manager
Manitex, Inc.
Georgetown, Texas
----- Original Message -----
Sent: Friday, July 09, 2010 3:32 PM
Regards,
--sf
