I found that if I take the tab that the DGV is on and undock it so it is visible when the records are loaded into it, that the links show up. If the tab is not visible at the time the records are loaded the links do not show up.
--- In vantage@yahoogroups.com, "jgiese1988" <jgiese@...> wrote:
> I have a DataViewGrid that loads records with links from sharepoint into Epicor. I convert the column with the paths to links and nothing happens? The exact same code works outside of Epicor in VS but as soon as I bring it into Epicor no dice? Thoughts?
