Date calculation for export utility
Nelson
I'm going to assume you have an existing export in export utilities.
I am familiar with Vantage 4.0, the instructions should work in 5.0 -
5.2.
Open the export in export utilities.
Click on the "Fields" tab.
select the field you want in the "Available fields" window on the
right.
You can select more than one field.
When the proper fields are selected click on the "select" button in
the center.
The field should now show up at the bottom the "Selected Fields"
window on the left.
Use the "move up" and "move down" to put the field where you want it.
Click on "OK" and the run the export.
If you had something else in mind let me know what it is. I use
export utility quite a bit.
Russ Dover
> Hi everyone,
> I need to add a date field to an exported file using the export
> utility. Can anyone help?
> Thanks,
> Nelson Dufour
> Colonial Tool Group Inc.
Russ Dover
IS Manager
Weaver Industries, Inc.
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
Hi everyone,
Nelson Dufour
