Date changes within BPM
Ignore the last email - all sorted
Thanks for the messages.
--- In vantage@yahoogroups.com, "roomurray" <rupert@...> wrote:
> That works TYVM - but only seems to work on line 1. On line numbers 2+ the value is null
> --- In vantage@yahoogroups.com, "netrippers" <netrippers@> wrote:
> > Progress has an add-interval function to manipulate dates.
> > Try Assign orderhed.date01 = ADD-INTERVAL(orderhed.created, 60, 'Days') The second parameter can be positive or negative. The third parameter is 'Days', 'Months' or 'Years'.
> > Tom
> > --- In vantage@yahoogroups.com, "roomurray" <rupert@> wrote:
> > > Thanks David,
> > > I've done similar, but what I need to achieve is to set other fields to calculated values. For instance when in the order entry screen
> > > orderhed.date01 = orderhed.created + 60 etc
> > > > > I'm looking to update date fields within BPM(s).
> > > > > What I need to do is take a date like today or a date already in a field and add a specific days/weeks/Months to that value and return it to a new date field.
> > > > > I've tried all sorts, but nothing has worked.
> > > > I have not tried doing a date change in a BPM, but I have done it in a BAQ calculated field. I used the following formula to add 60 days to a date:
> > > > Date(ShipHead.ShipDate) + 60
> > > > David
David
Thanks David,
> David
find first ttOrderDtl where ttOrderDtl.RowMod = 'U' or
ttOrderDtl.RowMod = 'A' no-lock.
if available ttOrderDtl then do:
assign ttOrderDtl.Date02 = TODAY.
end.
This is a sample of 4GL code we use on a massive customization that sets a
date filed. I'm sure there are other option other than "TODAY" that you can
use. TODAY + 30 or something of this nature.
~Charlie
_____
Dave Pfiester
Sent: Wednesday, May 06, 2009 8:56 AM
Subject: [Vantage] Re: Date changes within BPM
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
date field.
David
Tom
> Thanks David,
> > David
> Tom
> > Thanks David,
> > > David
