Date field update w/BPM
Nigel,
I am back from holiday and ready to tackle this again.
I did copy/paste your code exactly. There is nothing in the server
log. When I commented out Run lib comand, I still get the same errors.
The only new tidbit is that the OrderDtl.Date10 field seems to be
getting populated as desired. Of course since the error basically
kills Vantage, that is little consolation.
Andrew
--- In vantage@yahoogroups.com, "Nigel Kerley" <nigel.kerley@...> wrote:
> Is there any message in the mfgtest803.server.log (or
> mfgsys803.server.log if you're on the live db)? It's in
> \\server\epicor\mfgsys803\server\logs.
> Did you copy/paste my code? I've just tried it again and it works for
> me. Try commenting out the "Run lib\..." statement to see if that's
> the cause - put a /* before the line and */ at the end of the line -
> the line should turn green. Save it and trigger it and see what
> happens.
> Nigel.
> --- In vantage@yahoogroups.com, "andrew.tapper" <atapper@> wrote:
> > Problems again. I wish I understood this better so I could help
> > myself, but until then....
> > When I tried the new code I got two Application Error messages. The
> > first is..
> > Error Detail
> > 7175
> > Stack Trace
> > at Progress.Open4GL.DynamicAPI.Session.runProcedure(String
> > requestID, String procedureName, ParameterSet parms, Boolean
> > persistent, Boolean internal_Renamed, Int64 procId, MetaSchema
> > localSchema, Int32 stateModel)
> > at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure
> (String
> > requestID, String fullProcedureName, ParameterSet inparams, Object
> > procId, MetaSchema localSchema, Int32 stateModel)
> > at
> > Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String
> > requestID, String procedureName, ParameterSet parms, MetaSchema
> schema)
> > at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String
> > procedureName, ParameterSet parms, MetaSchema schema)
> > at Epicor.Mfg.Proxy.SalesOrderImpl.Update(SalesOrderDataSet ds)
> > at Epicor.Mfg.UI.Adapters.SalesOrderAdapter.Update()
> > at Epicor.Mfg.UI.App.SalesOrderEntry.Transaction.Update()
> > The second one is..
> > Error Detail
> > Tried to call a method in an invalid procedure. (7224)
> > Stack Trace
> > at Epicor.Mfg.Proxy.ReportMonitorImpl.GetRowsKeepIdleTime(String
> > whereClauseSysRptLst, Int32 pageSize, Int32 absolutePage, Boolean&
> > morePages)
> > at
> > Epicor.Mfg.UI.Adapters.ReportMonitorAdapter.GetRowsKeepIdleTime
> (SearchOptions
> > opts, Boolean& MorePages)
> > They pretty much kill the Vantage session.
> > Any Ideas?
> > Andrew
> > > I will try that. Thank you for the (always) great help.
> > > Just one more question for my own education. Does the Update bo
> only
> > > make temp tables for tables that have been changed? So since I was
> > > only making a change to the OrderHed table, then there was no
> > > ttOrderDtl tables generated. This would be one of those key
> nuggets of
> > > knowledge about how BPMs and BOs that would be really helpful to
> > > understand for the future.
> > > Thanks again.
> > > Andrew
> > > --- In vantage@yahoogroups.com, "Nigel Kerley" <nigel.kerley@>
> wrote:
> > > > I've just re-read your earlier posts and seen your mention of
> > > > "existing orders". Sorry, hadn't noticed it before.
> > > > Yes, it's possible but there is a complication. You need
> something to
> > > > "kick-off" the BPM, something that has the OrderNum. Problem is
> that
> > > > all your orders are already entered. So you would have to open
> each
> > > > order, tick a box/make a change and save the order. This would
> then
> > > > launch the BPM for that order.
> > > > If you decided to use the Hold flag (i.e. put the order on
> hold, save
> > > > it, then take it off hold, save it), then you would:
> > > > Add a condition: the ttOrderHed.OrderHeld field has been
> changed from
> > > > True to False
> > > > Add a 4GL Action:
> > > > find first ttOrderHed no-lock no-error.
> > > > if available ttOrderHed then do:
> > > > for each OrderDtl where OrderDtl.Company = ttOrderHed.Company
> and
> > > > OrderDtl.OrderNum = ttOrderHed.OrderNum no-lock:
> > > > if OrderDtl.Date10 = ? then do:
> > > > Run lib\UpdateTableBuffer.p(input BUFFER OrderDtl:HANDLE,
> > > > 'Date10',ttOrderHed.Orderdate).
> > > > end.
> > > > end.
> > > > end.
> > > > You have to use "Run lib..." instead of Assign as you're
> writing to a
> > > > "live" table and not a temp table.
> > > > If you have a large range of orders that you need to run this
> for, it
> > > > is possible (though more complicated) to "cheat" and run a BPM
> once
> > > > for all of them. I've done this by setting up a UD table to
> accept a
> > > > first and last Order# and running 4GL code on every order
> between the
> > > > two.
> > > > Nigel.
> wrote:
> > > > > That works, but there is still a problem.
> > > > > I would like an update to the OrderHed to update all the
> > > > > OrderDtl.Date10 records. As the code is, we would have to
> update
> > > > each
> > > > > line seperately, which we could do without any custom code.
> Sorry if
> > > > > this wasn't clear originally.
> > > > > Is this possible?
> > > > > Andrew
With a BPM in 8.03, is there an easy way to populate a user date field
with today's date on a GetNew? I was hoping to avoid writing 4GL code
for this, but maybe it is a good project to get my feet wet with 4GL.
Andrew
Hi Andrew,
I think 4GL is the only way to do this - other than a customisation
using VB.
The good news is that it's fairly easy to do. I'd create a post-
processing directive, add the 4GL action and use the following code:
assign ttOrderHed.Date01 = TODAY.
end.
Change "ttOrderHed" for whatever table you're storing the date field
in.
HTH,
Nigel.
field
code
4GL.
> Andrew
Thank you Nigel, your code worked perfect. Your mind reading skills
are also sharp - I needed to do the BPM to Order entry.
Hope I can return the favor someday.
Andrew
wrote:
> Hi Andrew,
> using VB.
> end.
field
> in.
> HTH,
> Nigel.
> field
> code
> 4GL.
> > Andrew
I am stumped again. The stuff shown below was so that I could add a
date to OrderDtl, but now I need to write some code to help update
existing order records and populate the OrderDtl.Date10 fields I added.
The following 4GL code almost works as a Post-Process BPM - it
populates the OrderDtl.Date10 field correctly but doesn't really save
it. That makes since since I am only updating the temp table, but when
I use the same code as a Pre-Process BPM it doesn't work.
for each ttOrderDtl where ttOrderDtl.OrderNum = ttOrderHed.OrderNum
no-lock.
if ttOrderDtl.Date10 = ? then do:
ttOrderDtl.Date10 = ttOrderHed.OrderDate.
end.
end.
end.
Can someone tell me what I am doing wrong?
Andrew
> Andrew
> wrote:
> > Hi Andrew,
> > using VB.
> > end.
> field
> > in.
> > HTH,
> > Nigel.
> > field
> > code
> > 4GL.
> > > Andrew
Hi Andrew,
Try this: a pre-processing directive against the SalesOrder.Update
BO, and make the code:
find first ttOrderDtl where ttOrderDtl.RowMod = 'U' or
ttOrderDtl.RowMod = 'A' no-lock.
if available ttOrderDtl and ttOrderDtl.Date10 = ? then do:
find OrderHed where ttOrderDtl.Company = OrderHed.Company and
ttOrderDtl.OrderNum = OrderHed.OrderNum no-lock.
if available OrderHed then do:
ttOrderDtl.Date10 = OrderHed.OrderDate.
end.
end.
This code will check each line as it's being saved and update Date10
if needed.
Nigel.
added.
save
when
> no-lock.
> end.
> end.
> end.
> Andrew
skills
> > Andrew
> > wrote:
> > > Hi Andrew,
customisation
> > > using VB.
code:
> > > end.
> > field
> > > in.
> > > HTH,
> > > Nigel.
date
> > > field
4GL
> > > code
with
> > > 4GL.
> > > > Andrew
I tried what you said and I got and error saying to check the
AppServer log. The error in the Appserver log is the following:
FIND FIRST/LAST failed for table ttOrderDtl. (565)
Any suggestions?
Andrew
> Hi Andrew,
> end.
> end.
> if needed.
> Nigel.
> added.
> save
> when
> > no-lock.
> > end.
> > end.
> > end.
> > Andrew
> skills
> > > Andrew
> > > wrote:
> > > > Hi Andrew,
> customisation
> > > > using VB.
> code:
> > > > end.
> > > field
> > > > in.
> > > > HTH,
> > > > Nigel.
> date
> > > > field
> 4GL
> > > > code
> with
> > > > 4GL.
> > > > > Andrew
I'm hoping that the error poped up for a line that you DID enter
Date10 for. Sorry, the first line should have a "no-error" after the
"no-lock", (but before the ".")
The error is saying that it couldn't find a line marked as "Added" or
"Updated". The "no-error" suppresses this.
Nigel.
> Any suggestions?
> Andrew
wrote:
> > Hi Andrew,
SalesOrder.Update
> > end.
> > end.
Date10
> > if needed.
> > Nigel.
add a
update
I
> > added.
really
> > save
but
> > when
ttOrderHed.OrderNum
> > > no-lock.
> > > end.
> > > end.
> > > end.
> > > Andrew
> > skills
> > > > Andrew
<nigel.kerley@>
> > > > wrote:
> > > > > Hi Andrew,
> > customisation
> > > > > using VB.
post-
following
> > code:
> > > > > end.
date
> > > > field
> > > > > in.
> > > > > HTH,
> > > > > Nigel.
user
> > date
> > > > > field
writing
> > 4GL
> > > > > code
wet
> > with
> > > > > 4GL.
> > > > > > Andrew
OrderDtl.Date10 records. As the code is, we would have to update each
line seperately, which we could do without any custom code. Sorry if
Is this possible?
Andrew
> Nigel.
> > Any suggestions?
> > Andrew
> wrote:
> > > Hi Andrew,
> SalesOrder.Update
> > > end.
> > > end.
> Date10
> > > if needed.
> > > Nigel.
> add a
> update
> I
> > > added.
> really
> > > save
> but
> > > when
> ttOrderHed.OrderNum
> > > > no-lock.
> > > > end.
> > > > end.
> > > > end.
> > > > Andrew
> > > skills
> > > > > Andrew
> <nigel.kerley@>
> > > > > wrote:
> > > > > > Hi Andrew,
> > > customisation
> > > > > > using VB.
> post-
> following
> > > code:
> > > > > > end.
> date
> > > > > field
> > > > > > in.
> > > > > > HTH,
> > > > > > Nigel.
> user
> > > date
> > > > > > field
> writing
> > > 4GL
> > > > > > code
> wet
> > > with
> > > > > > 4GL.
> > > > > > > Andrew
Yes, it's possible but there is a complication. You need something to
"kick-off" the BPM, something that has the OrderNum. Problem is that
all your orders are already entered. So you would have to open each
order, tick a box/make a change and save the order. This would then
If you decided to use the Hold flag (i.e. put the order on hold, save
Add a condition: the ttOrderHed.OrderHeld field has been changed from
True to False
Add a 4GL Action:
for each OrderDtl where OrderDtl.Company = ttOrderHed.Company and
end.
end.
end.
You have to use "Run lib..." instead of Assign as you're writing to a
If you have a large range of orders that you need to run this for, it
is possible (though more complicated) to "cheat" and run a BPM once
for all of them. I've done this by setting up a UD table to accept a
first and last Order# and running 4GL code on every order between the
two.
Nigel.
each
> Is this possible?
> Andrew
Just one more question for my own education. Does the Update bo only
ttOrderDtl tables generated. This would be one of those key nuggets of
Thanks again.
Andrew
> True to False
> Add a 4GL Action:
> end.
> end.
> end.
> two.
> Nigel.
> each
> > Is this possible?
> > Andrew
first is..
Error Detail
7175
Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String
at
requestID, String procedureName, ParameterSet parms, MetaSchema schema)
The second one is..
Error Detail
Stack Trace
morePages)
at
Epicor.Mfg.UI.Adapters.ReportMonitorAdapter.GetRowsKeepIdleTime(SearchOptions
Any Ideas?
Andrew
> Thanks again.
> Andrew
> > True to False
> > Add a 4GL Action:
> > end.
> > end.
> > end.
> > two.
> > Nigel.
> > each
> > > Is this possible?
> > > Andrew
My understanding is that, yes, Vantage only works with one temp table
at a time. When a user creates (say) a new sales order the temp table
is ttOrderHed (and the OrderNum = 0). The user then creates a new
line and the ttOrderHed is saved (and the OrderNum generated) and
Vantage switches to ttOrderDtl. When that line is saved, ttOrderDtl
is saved to OrderDtl and a new blank ttOrderDtl is creates.
So it's not just one temp table, it's also just one temp record in
that table.
Unless someone else know differently....
Nigel.
of
> Thanks again.
> Andrew
something to
that
each
then
save
from
> > True to False
> > Add a 4GL Action:
and
> > end.
> > end.
> > end.
to a
for, it
once
accept a
the
> > two.
> > Nigel.
update
> > each
Sorry if
> > > Is this possible?
> > > Andrew
happens.
Nigel.
> first is..
> Error Detail
> 7175
> Stack Trace
(String
> at
schema)
> The second one is..
> Error Detail
> Stack Trace
> morePages)
> at
(SearchOptions
> Any Ideas?
> Andrew
only
nuggets of
> > Thanks again.
> > Andrew
something to
that
each
then
hold, save
changed from
> > > True to False
> > > Add a 4GL Action:
and
> > > end.
> > > end.
> > > end.
writing to a
for, it
once
accept a
between the
> > > two.
> > > Nigel.
update
> > > each
Sorry if
> > > > Is this possible?
> > > > Andrew
Nigel,
I'm trying to use some of your suggestions for Andrew, to do the
following:
Create a new Sales Order
Fill in Customer
Check a custom field called Checkbox01
When the Sales Order is saved, the InvoiceComment field would fill
with the InvoiceComment information from another saved Sales Order.
Using the following code as a CreateNew Post Directive will fill the
"InvoiceComment" on the new Order every time, if I create a new Order
and apply no conditional statement.
Find first OrderHed where OrderHed.OrderNum = 10720 No-lock no-error.
if avail OrderHed Then do:
assign ttOrderHed.InvoiceComment = OrderHed.InvoiceComment.
end.
end.
I have tried every combination I can think of to get this to work when
a checkbox is checked (conditional statement) and nothing works. Have
tried it in both Update and GetNew.
I've also tried using
ttOrderHed:HANDLE,'InvoiceComment',OrderHed.InvoiceComment).
Also doesn't work
Any suggestions?
Would appreciate any assistance
Dave
8.03.406A Progress
Xybix
> Hi Andrew,
> end.
> end.
> if needed.
> Nigel.
Hi Dave,
Try creating it as a post-processing directive against the Update BO.
Use the condition: "number of rows in the (below) query is not less
than 1".
The query would be "for each ttOrderHed where ttOrderHed.CheckBox01 =
true"
Nigel.
--- In vantage@yahoogroups.com, "ofcwiz" <DavidH@...> wrote:
> Nigel,
> following:
> Fill in Customer
fill
Order
error.
> end.
> end.
when
Have
> Also doesn't work
> Any suggestions?
> Thanks
> Dave
> 8.03.406A Progress
> Xybix
wrote:
> > Hi Andrew,
SalesOrder.Update
> > end.
> > end.
Date10
> > if needed.
> > Nigel.
Thanks Nigel,
It looks like it's working.
I really appreciate your support on this site.
Merry Christmas to all the site members.
This task would be a lot more difficult without this site and its
members, so willing to share information.
Thank you,
Dave
8.03.406A Progress
Xybix
> Hi Dave,
> than 1".
> true"
> Nigel.
> --- In vantage@yahoogroups.com, "ofcwiz" <DavidH@> wrote:
> > Nigel,
> > following:
> > Fill in Customer
> fill
> Order
> error.
> > end.
> > end.
> when
> Have
> > Also doesn't work
> > Any suggestions?
> > Thanks
> > Dave
> > 8.03.406A Progress
> > Xybix
> wrote:
> > > Hi Andrew,
> SalesOrder.Update
> > > end.
> > > end.
> Date10
> > > if needed.
> > > Nigel.
Dave:
 I second that , and Merry Christmas to all.
Bill J.
Sent: Tuesday, December 23, 2008 5:00:09 PM
Subject: [Vantage] Re: Date field update w/BPM
Thanks Nigel,
Thank you,
Dave
8.03.406A Progress
Xybix
--- In vantage@yahoogroups .com, "Nigel Kerley" <nigel.kerley@ ...> wrote:
> Hi Dave,
> than 1".
> The query would be "for each ttOrderHed where ttOrderHed.CheckBox 01 =
> true"
> Nigel.
> --- In vantage@yahoogroups .com, "ofcwiz" <DavidH@> wrote:
> > Nigel,
> > following:
> > Fill in Customer
> fill
> Order
> error.
> > assign ttOrderHed.InvoiceC omment = OrderHed.InvoiceCom ment.
> > end.
> > end.
> when
> Have
> > Run lib\UpdateTableBuff er.p(input BUFFER
> > ttOrderHed:HANDLE, 'InvoiceComment' ,OrderHed. InvoiceComment) .
> > Also doesn't work
> > Any suggestions?
> > Thanks
> > Dave
> > 8.03.406A Progress
> > Xybix
> > --- In vantage@yahoogroups .com, "Nigel Kerley" <nigel.kerley@ >
> wrote:
> > > Hi Andrew,
> SalesOrder.Update
> > > end.
> > > end.
> Date10
> > > if needed.
> > > Nigel.
