Good Morning,
I need to get a metric on how long it is taking buyers to act on PO suggestions. I have an in-transaction data directive for when the PO suggestion is created on SugPODtl table where if there is at least one added row in ttSugPODtl table then action is to set the SugPODtl.Date05 field of the added row to today.
Good enough....
Now, how do I get the date from the PO suggestion Date05 into the PO detail Date05 when the suggestion is marked for buy and then generate PO's is run. I can see that the method is generate POs, but the data from the PO suggestion does not seem to be available in this method. I also can't seem to get a hold of the correct PO suggestion because when it's a new suggestion, it has its own PO suggestion ID, but no po number or line and the generate of the PO detail doesn't seem to have the suggestion ID in it.
Any ideas?
Thanks so much for you consideration!
Nancy
A lot of times the tables you need are not available, so you will need to go looking for them with a little custom code. If it is more of a report you are looking for, a BAQ would be able to find all of the above without coding as long as you have dates even UD dates set up at each interval you are measuring. It would even allow you to calculate the number of days between dates.
Brenda
Sent: Tuesday, September 22, 2015 8:57 AM
Subject: [Vantage] Date Stamp PO suggestion time of creation - put it into PO detail UD date05
Good Morning,
Good enough....
Any ideas?
Nancy
<div id="ygrps-yiv-233460092yiv8601181646ygrp-text">
<div>
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mkp #ygrps-yiv-233460092yiv8601181646hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mkp #ygrps-yiv-233460092yiv8601181646ads {
margin-bottom:10px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mkp .ygrps-yiv-233460092yiv8601181646ad {
padding:0 0;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mkp .ygrps-yiv-233460092yiv8601181646ad p {
margin:0;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mkp .ygrps-yiv-233460092yiv8601181646ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-sponsor #ygrps-yiv-233460092yiv8601181646ygrp-lc {
font-family:Arial;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-sponsor #ygrps-yiv-233460092yiv8601181646ygrp-lc #ygrps-yiv-233460092yiv8601181646hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-sponsor #ygrps-yiv-233460092yiv8601181646ygrp-lc .ygrps-yiv-233460092yiv8601181646ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646activity span {
font-weight:700;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646activity span span {
color:#ff7900;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646activity span .ygrps-yiv-233460092yiv8601181646underline {
text-decoration:underline;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 .ygrps-yiv-233460092yiv8601181646attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 .ygrps-yiv-233460092yiv8601181646attach div a {
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 .ygrps-yiv-233460092yiv8601181646attach img {
border:none;padding-right:5px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 .ygrps-yiv-233460092yiv8601181646attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 .ygrps-yiv-233460092yiv8601181646attach label a {
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 .ygrps-yiv-233460092yiv8601181646bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 .ygrps-yiv-233460092yiv8601181646bold a {
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 dd.ygrps-yiv-233460092yiv8601181646last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 dd.ygrps-yiv-233460092yiv8601181646last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 dd.ygrps-yiv-233460092yiv8601181646last p span.ygrps-yiv-233460092yiv8601181646yshortcuts {
margin-right:0;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div.ygrps-yiv-233460092yiv8601181646attach-table div div a {
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div.ygrps-yiv-233460092yiv8601181646attach-table {
width:400px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div.ygrps-yiv-233460092yiv8601181646file-title a, #ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div.ygrps-yiv-233460092yiv8601181646file-title a:active, #ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div.ygrps-yiv-233460092yiv8601181646file-title a:hover, #ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div.ygrps-yiv-233460092yiv8601181646file-title a:visited {
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div.ygrps-yiv-233460092yiv8601181646photo-title a, #ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div.ygrps-yiv-233460092yiv8601181646photo-title a:active, #ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div.ygrps-yiv-233460092yiv8601181646photo-title a:hover, #ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div.ygrps-yiv-233460092yiv8601181646photo-title a:visited {
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 div#ygrps-yiv-233460092yiv8601181646ygrp-mlmsg #ygrps-yiv-233460092yiv8601181646ygrp-msg p a span.ygrps-yiv-233460092yiv8601181646yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 .ygrps-yiv-233460092yiv8601181646green {
color:#628c2a;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 .ygrps-yiv-233460092yiv8601181646MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 o {
font-size:0;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646photos div {
float:left;width:72px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646reco-category {
font-size:77%;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646reco-desc {
font-size:77%;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 .ygrps-yiv-233460092yiv8601181646replbq {
margin:4px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mlmsg select, #ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 input, #ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mlmsg pre, #ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 code {
font:115% monospace;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-mlmsg #ygrps-yiv-233460092yiv8601181646logo {
padding-bottom:10px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-msg p#ygrps-yiv-233460092yiv8601181646attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-reco #ygrps-yiv-233460092yiv8601181646reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-sponsor #ygrps-yiv-233460092yiv8601181646ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-sponsor #ygrps-yiv-233460092yiv8601181646ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-sponsor #ygrps-yiv-233460092yiv8601181646ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-text {
font-family:Georgia;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-text tt {
font-size:120%;}
#ygrps-yiv-233460092 #ygrps-yiv-233460092yiv8601181646 #ygrps-yiv-233460092yiv8601181646ygrp-vital ul li:last-child {
border-right:none !important;}
Nancy:
I sent you my routines last night for saving the information into a UD table pre-processing and then retrieving them after generation.
Greg
Sent: Thursday, September 24, 2015 8:50 AM
Subject: [Vantage] Re: Date Stamp PO suggestion time of creation - put it into PO detail UD date05
Thanks very much for suggestions, but PO and PO Line are only completed if the suggestion is a change suggestion.
I need to get the time span from when a "new" suggestion was created to when the PO was generated. At time of PO generation, the new suggestion is deleted from the suggestion table. This is why I can't just use a query tie or report.
It seems pretty much one directional, system takes data from new PO suggestion and loads it into PO when users says to generate. I can't add suggestion create date sugPOdtl.Date05 data from suggestion to po POdtl.Date05 after generate, because the data is gone then (i.e., the po suggestion row has been deleted). I can't do it before generate, because the PO hasn't been made yet..
Thanks for your consideration!
Nancy
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
<div id="ygrps-yiv-843187362yiv5749296033ygrp-text">
<div>
</div>
<div class="ygrps-yiv-843187362yiv5749296033yqt5432902358" id="ygrps-yiv-843187362yiv5749296033yqt96050"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mkp hr {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mkp #ygrps-yiv-843187362yiv5749296033hd {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mkp #ygrps-yiv-843187362yiv5749296033ads {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mkp .ygrps-yiv-843187362yiv5749296033ad {
padding:0 0;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mkp .ygrps-yiv-843187362yiv5749296033ad p {
margin:0;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mkp .ygrps-yiv-843187362yiv5749296033ad a {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-sponsor #ygrps-yiv-843187362yiv5749296033ygrp-lc {
font-family:Arial;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-sponsor #ygrps-yiv-843187362yiv5749296033ygrp-lc #ygrps-yiv-843187362yiv5749296033hd {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-sponsor #ygrps-yiv-843187362yiv5749296033ygrp-lc .ygrps-yiv-843187362yiv5749296033ad {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033actions {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033activity {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033activity span {
font-weight:700;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033activity span:first-child {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033activity span a {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033activity span span {
color:#ff7900;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033activity span .ygrps-yiv-843187362yiv5749296033underline {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 .ygrps-yiv-843187362yiv5749296033attach {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 .ygrps-yiv-843187362yiv5749296033attach div a {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 .ygrps-yiv-843187362yiv5749296033attach img {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 .ygrps-yiv-843187362yiv5749296033attach label {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 .ygrps-yiv-843187362yiv5749296033attach label a {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 .ygrps-yiv-843187362yiv5749296033bold {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 .ygrps-yiv-843187362yiv5749296033bold a {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 dd.ygrps-yiv-843187362yiv5749296033last p a {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 dd.ygrps-yiv-843187362yiv5749296033last p span {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 dd.ygrps-yiv-843187362yiv5749296033last p span.ygrps-yiv-843187362yiv5749296033yshortcuts {
margin-right:0;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div.ygrps-yiv-843187362yiv5749296033attach-table div div a {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div.ygrps-yiv-843187362yiv5749296033attach-table {
width:400px;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div.ygrps-yiv-843187362yiv5749296033file-title a, #ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div.ygrps-yiv-843187362yiv5749296033file-title a:active, #ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div.ygrps-yiv-843187362yiv5749296033file-title a:hover, #ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div.ygrps-yiv-843187362yiv5749296033file-title a:visited {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div.ygrps-yiv-843187362yiv5749296033photo-title a, #ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div.ygrps-yiv-843187362yiv5749296033photo-title a:active, #ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div.ygrps-yiv-843187362yiv5749296033photo-title a:hover, #ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div.ygrps-yiv-843187362yiv5749296033photo-title a:visited {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 div#ygrps-yiv-843187362yiv5749296033ygrp-mlmsg #ygrps-yiv-843187362yiv5749296033ygrp-msg p a span.ygrps-yiv-843187362yiv5749296033yshortcuts {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 .ygrps-yiv-843187362yiv5749296033green {
color:#628c2a;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 .ygrps-yiv-843187362yiv5749296033MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 o {
font-size:0;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033photos div {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033photos div div {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033photos div label {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033reco-category {
font-size:77%;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033reco-desc {
font-size:77%;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 .ygrps-yiv-843187362yiv5749296033replbq {
margin:4px;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-actbar div a:first-child {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mlmsg {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mlmsg table {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mlmsg select, #ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 input, #ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 textarea {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mlmsg pre, #ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 code {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mlmsg * {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-mlmsg #ygrps-yiv-843187362yiv5749296033logo {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-msg p a {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-msg p#ygrps-yiv-843187362yiv5749296033attach-count span {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-reco #ygrps-yiv-843187362yiv5749296033reco-head {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-reco {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-sponsor #ygrps-yiv-843187362yiv5749296033ov li a {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-sponsor #ygrps-yiv-843187362yiv5749296033ov li {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-sponsor #ygrps-yiv-843187362yiv5749296033ov ul {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-text {
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-text tt {
font-size:120%;}
#ygrps-yiv-843187362 #ygrps-yiv-843187362yiv5749296033 #ygrps-yiv-843187362yiv5749296033ygrp-vital ul li:last-child {
