Date/User Stamp Customization
The change log was just an 'easy way out' (no customization required) as they are just as visible (within the app) as a memo.
You should be able to do what you want via the customization you suggested. Either add a button control to initiate the comment entry (as you suggested) or leverage the change field value event (failed qty field) to trigger the same if the value <> 0.
Good luck.
Rob Brown
Sean Toler <seantoler@...> wrote:
However I'm not sure that is exactly what I'm looking for. I want
the user name and current date to show up in the comments field like
it used to be back in 6.X.
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
wrote:
> You could probably get the same result if you enable change logging
for some appropriate field in the inspection record (perhaps qty
failed).
> That would save the user/date:time of any change to a record in
the selected field. You can view it through the applicaitons change
log Action.
> Rob Brown
> Hello,
> In previous versions of Vantage, there was a Date/User Stamp button
on
> the comments tab for Nonconformances. I noticed that with the
release
> 8.0 it was gone. I have seen that they have readded this type of
> button to similar comment fields in other modules. Is there a way
that
> I can add this type of a button using customization?
> Never miss a thing. Make Yahoo your homepage.
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
Hello,
In previous versions of Vantage, there was a Date/User Stamp button on
the comments tab for Nonconformances. I noticed that with the release
button to similar comment fields in other modules. Is there a way that
You could probably get the same result if you enable change logging for some appropriate field in the inspection record (perhaps qty failed).
That would save the user/date:time of any change to a record in the selected field. You can view it through the applicaitons change log Action.
Rob Brown
Hello,
failed).
log Action.
> Rob Brown
> Hello,
on
release
that
